Old 10-28-2013, 10:18 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Dominion Industrial Band Saw.....worth anything????
I've got an older Dominion DS 50 industrial band saw. It's just like this one http://yukon.kijiji.ca/c-buy-and-sel...AdIdZ525076385 Does anyone know anything about these? Right now it's not working. I tried plugging it in and there's no power. I'm assuming it needs a new motor. Is it worth replacing the motor? Would I get anything if I fixed it and sold it? Or should I just haul it off to the dump? Any info would be greatly appreciated.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 10-28-2013, 10:44 PM
Sieg's Avatar
Sieg Sieg is offline
A "decent" Asian 64.5" dry saw will run $300-$375 new. Far from a high quality accurate cutting saw. After owning one I'd be lost without one.
This one looks to be a lot higher quality than what I've got so I'd say it's worth making operational. If sold as is I wouldn't exactly give it away.
Old 10-29-2013, 10:42 AM
Mike -- Make sure it's not some "industrial" voltage or phase!
I bought a Baldor grinder once -- and it arrives and it's 208V…. and that's a non starter.
Old 10-29-2013, 10:43 AM
Sorry -- should have read the post ------ I thought you were interested in BUYING it --- not selling one.
The electrical still could be as I stated above which is why it won't run?
Old 10-29-2013, 11:00 AM
Ketzer's Avatar
Ketzer Ketzer is offline
FWIW, I just bought an old horizontal from some friends of mine. The catch, it was three phase. I bought a converter for $100 and it works like a charm!
Check the label on the motor.
Jeff-
