Old 10-28-2013, 09:40 PM
Power Power is offline
Default Need help with large MII brake options
I have a TCI front with MII spindles on my 67 nova. This came with the less than desirable small cast disc brakes. What are the cheapest options/up grades for this set up? I read all the time ppl using corvette or Cadillac brakes but am unsure of what I can use other than wilwoods.
Old 10-29-2013, 10:07 AM
Thoughts? I'm just trying to keep from making a costly mistake.
Old 10-29-2013, 10:56 AM
dontlifttoshift's Avatar
If you ordered the front end, then the costly mistake was not ordering it with the brakes you wanted then.
If it was already on the car then it is pretty hard to beat Wilwood....and you need to ask yourself a lot of questions. Intended usage, budget, wheel size, etc.
Donny
Old 10-29-2013, 12:26 PM
Donny,
Thanks for the lesson however I purchased this car with the TCI already installed. Just a street car but want large brakes bc they look cool.
