Old 11-03-2013, 09:45 PM
69 blue coupe 69 blue coupe is offline
Default 2010 camaro tr6060
What u guys think about putting this trans into a 69 camaro with a l92? Should I or should I not
Old 11-22-2013, 04:39 PM
gnx7's Avatar
gnx7 gnx7 is offline
i don't like the gearing in them as they are for a heavy pig. That is the main downside IMO.
the mainshaft (output shaft) has a 3 finger flange on it requiring an adapter to make it mate up to a more common 6 bolt flange and then a slip yoke built into the driveshaft. meaning more expensive driveshaft by a couple hundred or more.
http://www.driveshaftshop.com/domest...nversion-plate
the bellhousing is also one piece integrated into the front bearing plate.... so if you wanted to put on an SFI bellhousing it is a custom setup $$$.
Just get a T56 Magnum with the 2.66 1st gear ratio. Then 5th gear is nice and close (.80 ratio) to stay in your powerband.
