Old 11-15-2013, 01:44 PM
srh3trinity srh3trinity is offline
Default z51 Corvette brakes, RideTech brackets, 18x8.5 and 18x9.5 wheels/tires
Just like everybody, things change with a project so I have some parts to sell off. I figured I would offer up to you guys for a week before they go on Ebay.
First up is a C6 Z51 Corvette brake setup. With this comes the two front two piston calipers and abutments along with the OE hoses. I have one of the front rotors (the other one went to the machine shop for machine down a hub assembly and got misplaced). Two rear calipers with abutments and two rotors. The three rotors I do have are in good shape. I also have the very difficult to find parking brake setup with the backing plates and shoes in place ready to bolt up. They are going to need some elbow grease and paint or powdercoat. Rotors are 13.4" up front and 13" out back. Keep in mind the parking brake plates are very difficult to find and you can look at the upcharge on the Kore3 website to see how much they influence the rear brake kit price. I will listen to offers and I will consider breaking this up. $850 plus shipping (rotors are heavy).
Next up is a set of RideTech four link brackets. I was going to go with a custom rear end and I was going to have these welded on. They take the place of the bracket that would normally bolt on to the spring perch and really clean up the install. I am going to use my stock axle, so I am just going to use the bracket included with my RideTech four link setup. Here is the link on their website: http://www.ridetech.com/store/weld-o...ch-4-link.html I will go 125.00 shipped on these.
Finally, I have a set of wheels and tires that I had bought to run on my car. After buying a different subframe, they won't work. They are Privat Legende's in 18x8.5 and 18x9.5 with 35 MM offsets (6.13 inch BS and 6.63 inch BS respectively). They are in a nice textured graphite with a brushed lip. These are made by Konig and are their upscale line. Bolt pattern is 5x120. I was going to run adapters and based on my calculations, with the adapters, the BS should work well with most muscle cars. They are brand new and I mounted a set of mock up tires on them only. Otherwise, they have been sitting in my garage. The tires are BFG KD's that I bought from RideTech, they have plenty of tread, but are older and the tread is hard. They would be fine for around the town summer tires or for mock up purposes. The tires are 245/40/18 up front and 275/40/18 out back. I am looking for $800 plus shipping on these.
Shoot me a PM or respond here. Likely will go to eBay in a week or so. Parts in Birmingham, AL
Stephen
Old 11-15-2013, 07:44 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Check your messages on the wheels. I'm interested in them. Seriously.
Jim
Old 11-15-2013, 08:25 PM
jovozx12's Avatar
jovozx12 jovozx12 is offline
Interested in the link brackets and the rear brakes. Do the rear brakes bolt to a 10/12 bolt axle?
Old 11-15-2013, 08:44 PM
The brakes would need a caliper bracket to bolt up to a 10/12 bolt. The bracket can probably be bought separately from Tobin at www.kore3.com
Stephen
Old 11-15-2013, 08:57 PM
Replied to PM's and added a location on the parts. I thought I had put that in the ad in the first place.
Stephen
Old 11-16-2013, 09:18 PM
gordonr1973's Avatar
gordonr1973 gordonr1973 is offline
PM sent.
Old 11-17-2013, 10:59 AM
Pm's replied to.
Stephen
Old 11-17-2013, 06:36 PM
jovozx12's Avatar
Pm. Sent
Old 11-22-2013, 02:45 PM
TTT for the weekend.
Stephen
Old 11-23-2013, 03:46 PM
PM's replied to.
Stephen
