Old 11-19-2013, 05:08 PM
Swain's Avatar
Swain Swain is offline
Default Best oil pan to use on DSE subframe
Running a DSE sub. On my 68 camaro
Not using their set back plates. Stock LS3 pan will not clear.
What's everyone running?
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 11-19-2013, 05:15 PM
Musclerodz's Avatar
Gonna have to use a Holley or Mast pan if you want a cast pan, or Canton if your willing to go steel. The LS3 crate motor pan just barely clears with the set back mounts.
Mike Redpath
Musclerodz & Customz
facebook page
Old 11-19-2013, 05:27 PM
Swain's Avatar
Ya I also have a milodon. But didn't really want to run a remote oil filter. Guess I'll have to if I keep it.
I'll look into a Mast pan too thanks for the info
Jason Swain
Old 11-19-2013, 06:13 PM
Musclerodz's Avatar
canton does not use a remote filter.
Mike Redpath
facebook page
Old 11-19-2013, 06:54 PM
Efi69Cam Efi69Cam is offline
according to the information DSE has here: http://detroitspeed.com/1967-1969-F-...-subframe.html
Both of their mounts should clear the C6 pan.
Have you tried to install the engine with the c6 pan and found it does not clear?
Old 11-19-2013, 07:44 PM
Swain's Avatar
Says you need the set back mounts I have them but my shifter sits too far back I didn't like it so I put the normal ones back in
Jason Swain
Old 11-20-2013, 07:14 PM
Try a 4th gen fbody pan. You can get them brand new for $200.
Old 11-20-2013, 10:07 PM
Musclerodz's Avatar
only works with setback mounts per dse specs. They are more than when you add in the pickup tube.
Mike Redpath
facebook page
Old 11-21-2013, 06:34 PM
The information that came with my DSE subframe (few years old now) says the 4th gen pan works with the forward mount.
Any pan you'll buy will need a pickup tube. The mast pan runs over $400 does a pickup tube cost $200+? If the 4th gen pan works it's the most economical option.
Old 11-21-2013, 07:16 PM
Musclerodz's Avatar
pickup tube is over $100 and factory dip stick is about $40
Mike Redpath
facebook page
