Old 11-20-2013, 06:07 AM
Rick D's Avatar
Rick D Rick D is offline
Default Ls 6.0???
So IF I decide to go with a LS motor what is the best 6.0 to look for??? I found a 99 with 132K on it complete with everything included for $950??? I even get the harness.
Just not sure where to start "if" I go with a LS??
Rick
Old 11-20-2013, 06:32 AM
mikels mikels is offline
There really isn't a 'bad' LS 6.0L out there. There are several options and differences though.
LQ4 - Fe block / Al cathedral port heads / 24x crank
LQ9 - Fe block / Al cathedral port heads / 24x crank
LS2 - Al block / Al catherdral port heads / 24x (2005 Corvette / 2006 Trailblazer SS) 58x after
L76 - Al block / Al rectangular port heads / 58x crank
LY6 - Fe block / Al rectangular port heads / 58x crank
The early LQ4 / LQ9 engines were (and still are) very popular for building boosted motors as the iron block withstands considerable power before becoming a liability - and was available long before LSX block and other 6 bolt head blocks were available. Weak point is 4 bolt heads once >~1200 HP as head gaskets lack clamp load to withstand.
Aluminum block options are much more appealling from a mass perspective, but newer and more costly to puchase.
As far as the 24x vs. 58x crank signal - if building the engine, is not an issue and can make whichever you prefer (there are advantages to later 58x software / controllers).
Cathedral vs rectangular port heads - same thing - if you are changing heads, doesn't matter. If not, rectangular heads lack capability to reach airflow limits that rectangular ports can.
Since you mention a '99 - I assume it's either an LQ4 or LQ9. Only differences are the compression ratio (and calibration). LQ4 was 87 oct engine / LQ9 was premium. Both are great engines.
Bottom line - there are no bad choices - just depends on your goals and budget.
Old 11-20-2013, 08:18 AM
jwcarguy jwcarguy is offline
Banned
Just to add a couple notes:
the LQ9 6.)l didn't start production until 2002, so any earlier one will be the LQ4
The 99' & 2000 engines came with a iron block AND iron cyl. heads
Another difference in the pre 05" 6.0L is the LQ4 did have lower compression as mentioned before, but also has lighter duty connecting rods w/ press fit wrist pins
Where as the LQ9 came with the higher compression and heavy duty connecting rods w/ floating wrist pins, crank is alittle heavier due to the added rotating mass weight also
I say "pre 05' ", since 2005 - up, the Vortec series engines came equipped with the stronger bottom end with heavy duty crank, connecting rods and floating pistons w/ coated skirts
Old 11-20-2013, 10:20 AM
Rod P's Avatar
Rod P Rod P is offline
great info
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 11-20-2013, 11:32 AM
im4u2nvss im4u2nvss is offline
Beware of the "early" iron head LQ4. The early ones have a longer crank with no spacer. Depending on your transmission choice, this may not be a problem. LS1 t56 would be a no go. On the later model 6.0 you would just remove the crank spacer.
Old 11-20-2013, 03:35 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Rick I did not know we're anything but ls engines for these cars,you will be satisfied if you do get a 6.0 or 6.2,good luck and show us some updates.
Old 11-20-2013, 08:00 PM
ADiCarlo ADiCarlo is offline
I purchased a LQ9 with LS3 heads and a upgraded cam. It was used as a test mule for Hot Rod magazine to test the increased power of different cams.
The last configuration made 530 on the dyno but the piston to valve clearance was really close. Most guys running these numbers will throw in dished pistons to compensate.
I think ultimately it depends how far your going to go with the motor and how custom you want to get. If you want something to throw in and drive an aluminum LS is a easy win. But if your going to stroke it, run high compression, boost it, I would go with the iron block because it can take a better beating.
Also FYI the iron to aluminum LS is approximately 80lbs more which is not alot when you look at the safety of running iron to aluminum.
-Armand
Old 11-21-2013, 05:41 AM
Rick D's Avatar
Wow great info thanks to all that replied
Not looking to boost it well not to start just looking to keep the cost down. Really want to come up with my plan see how much it will hurt the budget and then go from there.
As for the motor I just want freshen it up and of corse get the most out of it. It's a street car so I'm not all that concerned about the 80lb difference, I'm sure the iron block setup is about the same as a SBC, or close.
As for which one I think I'll look for an lq9 as it would make alittle more power with the right cam, heads, and intake?
Here's another question, I want to run the carb intake, maybe even start with a carb? I was thinking to run a set of L92 heads as they seem to be a real good lower cost option and make nice power?
I guess what I'm asking is what would a good setup be for the lq9? Carb, cam, heads, and intake?? I may run EFI later but for now to keep the cost in line I thought a carb setup would better on the budget?? Maybe I'm wrong in my thinking???
Rick
Old 11-21-2013, 07:24 AM
NvrDun71 NvrDun71 is offline
If you are already thinking Lq9 with an LS3 head swap, skip a step and pick up a LY6 6.0. As they already come with the square port heads and have valve reliefs from the factory for increased PTV clearance with bigger cams. Best bang for the buck out there IMO. Hit up Pat G over on ls1tech for a custom cam spec for your intended application, One of the best in the business and will get you headed in the right direction.
71' Nova - LY6, T56
Old 11-21-2013, 06:32 PM
ma73z's Avatar
ma73z ma73z is offline
Rick, as a guy building a 2nd gen with a carbed 6.0. I'd say you're not going to save much money going the carb route, by the time you get all the parts your going to spend about the same amount as EFI, you also won't run into hood clearance problems . Just my opinion.
Matt (amateur jack stand class)
73 Camaro in slooow process
69 Firebird LS1 4l60E
70 Chevelle 402bb tko600
