Old 11-24-2013, 08:01 PM
whiteknuckle whiteknuckle is offline
Default Need Input , Third Gen F Body Going Wider
ok, so its going out of control lol....
the car is going to paint in a few months, im going to widen the front fenders to match the width of the rears, and make custom louvered vents into the tops of the fenders to release air pressure. im already using a 2 inch spacer up front with vett wheels, i would rather us no spacer at all, or at most a 1 in.. but do to the wider fenders, the track width up front needs to go wider as well, im already doing custom built coilovers and brembo 6 piston brakes 14 inch rotors blah blah blah.... anyway, due to my coilovers i need to make custom camber plates for my setup as it i anyway. im thinking i should make a fully adjustable lower control arm set that is actually 2inches wider then stock, so it will have a 4 inch wider track width up front and ill obviously need to make a longer tie rod set as well, and make the camber plate to correct the strut angle? any ideas????
anyone with in put will be greatly appreciated
