Old 12-02-2013, 05:09 AM
ccracin's Avatar
ccracin ccracin is offline
Default Aluminum Gage
So, I'm in the process of making the under hood trim panels for our project. I made the Radiator cover out of 18ga. (.047") steel. This was mostly to resist bends and dings from leaning in under the hood. I am considering making the rest out of 3003-H14 Aluminum. My question is, what gage? I have been back and forth in my own mind between 16 ga. (.05") and 18 ga. (.04"). What have you guys used and what are the pros and cons? I'm not opposed to staying with steel and just bumping down to 20 ga. (.036") I guess my only motivation for moving to aluminum at this point is weight. Help me out here!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 12-02-2013, 06:18 AM
kennyd's Avatar
kennyd kennyd is offline
most of the inner fenders do are out of .080 ,then places where we are not worried about rocks are .063
Old 12-02-2013, 06:29 AM
ccracin's Avatar
Thanks for the reply Kenny. These will not be subject to rocks. I have steel inner fenders. These will be trim panels only covering the steel inners. So, in that case .063? Do you use 3003?
Chad
Instagram - @cctek
