Old 05-03-2006, 09:19 PM
x-tream x-tream is offline
Default widest wheel and tire combo on 68 ????
I just purchased the new upper and lower control arms from air ride along with there shockwave shocks. ialso have a 2 inch drop spindle from heids. I was wondering what the widest wheel and tire combo i can go with is using an 18" wheel is??
Old 05-04-2006, 08:23 AM
markss28 markss28 is offline
I like 18x8s but I have seen 18x9s but you still have to make sure you ahve the right backspacing and you might need to roll or shave the lip. try to find someone that has an 18x9 and see if they will fit but for sure 18x8s no problem.
Never Stay Stock
Old 05-04-2006, 09:00 AM
Opm Customs Opm Customs is offline
Default He is right
[IMG][/IM
255 35 zr18's on 18X8
275 30 zr18's on 18X10
www.opmcustoms.com
Old 05-04-2006, 03:05 PM
novajess1972 novajess1972 is offline
If you are referring to a 68 camaro or nova, you can do any 8in wide wheel with 4-4.5in BS in front and at least a 9in in rear with 5.25-5.5in BS. I had this combo on my 1971 Nova. 17x8 front and 18x9 rear. I would insert a [IMG]pic, but I don't know how to do it.
Hope this helps.
Old 05-11-2006, 01:54 PM
MaxHarvard's Avatar
mine are 17x9.5 in the back with 275r40's
works pretty slick
this pic just shows that they dont stick out either
Old 05-11-2006, 04:29 PM
jcam68 jcam68 is offline
Max, what size and backspacing are you running on the front??
Old 05-11-2006, 10:30 PM
I am not so worried at the back as i am at the front. I am just gonna get the widest possible for the back and make them fit. What size of tire would i need for a 18x9 up front?? i realize i will have to roll the fender lip for them to work.
Old 05-12-2006, 02:37 PM
Novette_71's Avatar
Novette_71 Novette_71 is offline
mine are 10x18 on the back and i really think they look tiny ... like pizza cutters . I am looking forward to get my 10,5x19 or 10,5x20 Breyton Spirit Black
i think you can easily squeeze 10,5 inch with 275 or even 285 on the back of a 1971 nova depending on how low you want to go.
on the front i have 8,5x18 wanna upgrade to 9,5x18 ...
you know BMW wheels fits great on chevys because of the bolt circle, and depending you choose 3 series or 5/7 series you get all kinds of backspacings and it is easy to find the right rim.
Old 05-15-2006, 09:13 AM
On a camaro go with 18x10 for sure you will fit them. I have seen a few 1st gens with this and it works great just get the back spacing right. Alot of people say that they will stick out but not really to bad at all. As far as the front goes. if you have tubular control arms you can get more off-set like 4 3/4 that should fit. Plus if you need a bit more you can put on wheel spacers to fit. I really dont like doing that but its jsut and idea.
Never Stay Stock
