Old 12-03-2013, 10:57 PM
U-turn U-turn is offline
Default Is a Ridetech coilover spring rate change needed after LS swap???
I have recently swapped my aluminum headed SBC to a LS3. Is it necessary to change out my Ridetech coilover (single adjustable) spring to a different rate?
Thanks,
Cole
Old 12-03-2013, 11:13 PM
gerno's Avatar
gerno gerno is offline
I was told by the Speedtech guys that generally the LS and SBC are close enough in weight that a spring change is not necessary.
Old 12-03-2013, 11:14 PM
Rod P's Avatar
Rod P Rod P is offline
Thanks,
Cole
what were you running before?
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 12-03-2013, 11:55 PM
Vince@Meanstreets's Avatar
spring rate did you have prior to the swap?
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-04-2013, 05:40 PM
Thanks guys!
I am unaware of what rate I have now. It was speced when I ordered the complete front end kit with truturn from Ridetech. At that time I had a SBC.
Ill see if I can find out.
Cole
Old 12-05-2013, 04:20 AM
Supporting Vendor
According to this post:
http://www.pro-touring.com/threads/9...-vs-sbc-weight
which got the info from GM, the weights are:
19244097
LS3 = 415lbs (LS1 = 409lbs)
19201330
ZZ4 = 511lbs
http://www.chevroletperformance.com/...inePreview.pdf
So if you are looking at motors alone, and they are placed in the same position, you'll change only 100#. If you changed transmissions as well, you'll have to figure that into the equation.
If your car is an "average" 3500#, 55% on the front is 1925#. So 100# is only 5% of the total front weight. Probably not enough to require a spring change (depends on rate, but you're likely ok).
The easiest thing to do is get the swap done then drive the car and let your butt dyno tell you what it thinks. That's the nice thing about true coil overs. . .you have a ton of spring rate choices, and you can change them at any time for not much coin!
Skunk Werks
Ridetech
www.ridetech.com
