Old 05-04-2006, 04:36 PM
V8bug V8bug is offline
Default torque converter problems
I have a 283 sbc around 9.5:1 cr with a summit 1103 cam, 214/224 .442/.465.
It has a tpi intake and megasquirt controlling fuel and ignition. I got the car to idle inbetween 900-1000rpm, any lower and it gets unstable and stalls.
when I drop the car into any gear the rpms drop to around 500rpm and the engine stumbles for about 4 seconds and dies. To get it to run in gear I either have to raise the idle to about 1200rpm (but then it makes violent clunk when shifted into gear) or I have to catch the engine before it dies and keep on the gas.
This is no way to have my car operating. I have thought about changing the cam and decided against that. The torque converter in there now is a summit
SUM-G2700 that they say has a flash stall of 1700 rpm, feels like a stocker though?
should I buy a converter with more stall?
The car in question is a 71' vw bug with a ford 9" and 2.75 gears
any help would be great!!
