Old 12-09-2013, 11:06 AM
chichirone's Avatar
chichirone chichirone is offline
Default Brake Pad Upgrade?
Anyone have a suggestion for brake pads for my 69 Camaro? I'm running Baer Brakes 6P's up front and T4 on the rears. The current pads are the ones that came with the Baer brake kit when it was installed. My car weighs about 3600lbs and I'm running Dunlop Direzza Zii tires. I run the car on the street, autocross and am looking to do some ASCS events in 2014. Any suggestions would be appreciated.
Jay
1973 Trans Am "KLRBRD"
1969 Camaro SOLD
2014 Stingray Z51 SOLD
Old 12-09-2013, 11:17 AM
Sieg's Avatar
Sieg Sieg is offline
Hawk HP Plus pads cross over well, good bite, no warm up issues........but if you even glance at them they'll thoroughly dust your wheels.
Old 12-09-2013, 07:40 PM
Apogee Apogee is offline
X2 on the Hawk HP Plus...just don't make eye contact and you'll be fine...but only because you won't be looking at your wheels.
As for pads, have you driven the Baer supplied pads yet (Roulands)? If so, how do you like them? Even at best, opinions on pad compounds between different cars tend to be very subjective, and what I like on my car may not be what you like on yours. If you have some baseline to help establish your expectations, that can be very helpful. In addition, manual or power brakes? If power, vacuum assist or Hydroboost? If vacuum assist, booster size and configuration? MC bore size?
Tobin
KORE3
www.kore3.com
Old 12-09-2013, 09:00 PM
chichirone's Avatar
Tobin
KORE3
Good points. I'm new at this so appreciate the insight. I have driven on the pads quite a bit. I liked them a lot when new however I feel they tend to fade pretty quickly now, as I feel they have lost their bite. Not sure if this is "normal" or time to replace. My brakes are power. Vacuum assist. Would love to convert to hydroboost down the road. I need to look up the MC bore but I think its 1-1/8". I just can't recall off the top of my head. I'd be happy to replace with the same Rouland pads but wasn't sure if you guys would suggest an upgrade such as the Hawk HP's with my set-up.
Jay
1969 Camaro SOLD
Old 12-09-2013, 10:24 PM
Sieg's Avatar
Tobin brings up a good point with manual vs. power assist. The initial bite of the pad (HP+ and comparable) with power assist may be too aggressive for your desire. He's a trusted source with insight and exceptional knowledge.
Old 12-10-2013, 05:12 PM
Uh-oh...I feel like I'm being buttered up for something
Considering the 200 UTQG tires and intended auto-x and ASCS events (I'm assuming you mean the American Sports Car Series, not American Sprint Car Series), the more aggro the better really so long as the tires can handle it and it doesn't compromise modulation and control, which I don't think it will. I do think the Hawk HP Plus, EBC Yellowstuffs, or something similar with a GG friction rating would be a good option for your application. Who cares about dust if they're doing what they're supposed to be doing?
Tobin
KORE3
www.kore3.com
Old 12-10-2013, 09:36 PM
CarlC CarlC is offline
Tobin is right on (no buttering ;-) ).
I've settled on the HP+ as a very good all around pad. They held up to One Lap with no problems and work fine on the open road when cold. Lots of initial bite which means being a bit cautious when plenty of power assist is available.
But, I don't even have to look at them to dust the rims. I've given up chasing that demon. It is what it is, but they do work.
http:www.vaporworx.com
Old 12-10-2013, 09:52 PM
Sieg's Avatar
I certainly don't.
I explained what I wanted and you delivered exactly that....noting the dusting issue as well.
With the manual master they're prefect and they bite so well I can't believe they don't misbehave on the first couple cold stops, but they don't.
Old 12-11-2013, 08:50 AM
SSLance's Avatar
SSLance SSLance is offline
**sitting back and taking notes**
Will be making this decision myself sometime soon.
Sounds like EBC yellow or HP+ are my lead choices so far.
I'll be replacing rotors at the same time, stock style most likely, 9.5"...with GM metric calipers. If starting from scratch, does anyone feel there a better rotor choice or different choice between those two pad choices above?
Use will be a mix between fun street and regular autocross events.
Lance
Old 12-11-2013, 03:02 PM
chichirone's Avatar
Tobin
KORE3
Tobin, thanks for the input and guidance. Very helpful. Plus, if it's not at least a little dirty, its not being driven enough. Sounds like I will have no shortage of brake dust cleaning.
I really appreciate you, CarlC's and Sieg's input. This is a great site and I have to say I am really appreciative/impressed of everyone's willingness to educate and support other members, especially us newbies.
Jay
1969 Camaro SOLD
