Old 12-11-2013, 09:36 AM
hotwhls's Avatar
hotwhls hotwhls is offline
Default Electric Fans 12 vs 14
This winter I am going to install a electic fan as a pusher. (No room for puller) I am looking at getting a 12in 2300 cfm or a 14in 1850 cfm fan. The Radiator is only 16.5 tall so I can't go any bigger than that. My question should I go bigger with less cfm or smaller with more cfm. No I will not shroud the fan either. Whats your oppinion is the bigger fan have more cooling since is will take up more area on the radiator or will the smaller the fan with more cfm cool better.
Old 12-11-2013, 09:44 AM
67Rally's Avatar
67Rally 67Rally is offline
Why not shroud the fan? There are some pretty thin shrouded electric fans out there. They are a lot more efficient at cooling than a basket fan.
Also puller fans are going to cool a lot better than pushers.
You're making two choices that will both hurt your cooling ability.
Old 12-11-2013, 09:57 AM
hotwhls's Avatar
This is going on a inline 6 with NO room for a electric fan puller. I already have a NON-electric fan as a puller. I want to add some cooling for the stop and go cruising. I don't want a shroud yes I know they help.
Old 12-11-2013, 04:29 PM
67Rally's Avatar
Gotcha. In that case I would go with the CFM's.
Old 02-19-2015, 02:32 PM
gray86hatch gray86hatch is offline
From my experience a pusher fan is not to help.
Spal makes some fans that are 1.5" thick. I would think you could offset a pair as pullers and get rid the the mech fan.
Tim
86 mustang
454 lsx FTI ls3 mast 4500 9.24 144 pump gas dragradials
79 z28 29k org miles. DSE suspension Bonspeed GTB
Old 02-19-2015, 09:17 PM
A stock clutch fan and good cooling system shouldn't need any help. I think you have a problem that needs addressed.
Old 02-20-2015, 05:54 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
IMO, you would be better off removing the stock fan and installing a 3000+ CFM electric puller fan.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 02-26-2015, 01:53 PM
Justin@EntropyRad Justin@EntropyRad is offline
A larger diameter fan is better, however electric fan generally do not work well on copper/brass radiators because the cores are so restrictive. Stick with stock clutch fan.
