Old 12-16-2013, 01:04 PM
OBeer-WAN-Kenobi's Avatar
Default How about some clutch recommendations?
Hi all,
I split my donor (2004 GTO) engine and transmission this weekend to have a look and I think I'd like to put a new clutch in while I've got it apart. In actuality, the clutch doesn't really have that much wear but there are hot spots and chatter on it so I think the previous owner was one of those people that shouldn't have been driving a manual. I found out no one around here faces pressure plates anymore and I can't even order just the clutch disc itself so it looks like I'll have to buy new.
Anyway, I'm looking for a good value replacement, and even a stock one might be OK for now. My eventual goal of "as close to 600 RWHP I can get" doesn't really need to factor in here as that will be a long while due to funds. I've got a lift so I'm not too worried if I need to change it out later. However, as with a lot of my build, I'm over-doing it where it makes sense financially with my end goals in mind.
I'd like to not have to mess with bell-housing extensions and other weird stuff for now but would like to get a good daily driving clutch that will hold as much torque as possible for a reasonable price.
Thanks!
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 12-16-2013, 02:06 PM
NvrDun71 NvrDun71 is offline
GM LS7 clutch kit
71' Nova - LY6, T56
Old 12-16-2013, 06:43 PM
Originally Posted by NvrDun71 View Post
GM LS7 clutch kit
Doesn't that require a bell housing spacer or something? I thought I read that somewhere but maybe I'm wrong.
'69 RS Camaro
Old 12-17-2013, 10:55 AM
No special bellhousing or spacers required. They are good bang for the buck, have smooth operation, and can hold up to some power. Mine needed a small slave shim for proper engagement but was a direct bolt in otherwise.
71' Nova - LY6, T56
Old 12-17-2013, 01:07 PM
I think I may go this way then when budget allows. I like running off the shelf parts whenever possible so this is up my alley.
'69 RS Camaro
Old 12-17-2013, 07:32 PM
71RS/SS396's Avatar
600 rwhp will be right on the edge of what the LS7 clutch can handle.
Old 12-18-2013, 11:45 AM
67Rally's Avatar
67Rally 67Rally is offline
I have a Monster Level 2 in mine and I'm very happy with it. I think it's a little firmer than stock, but I wouldn't have any issue DD'ing it. It's good for up to 550 ft/lbs.
I got it from Tick Performance:
http://www.tickperformance.com/monst...-capacity-550/
Old 12-18-2013, 11:46 AM
67Rally's Avatar
I looked at the LS7 clutch, but I was advised that they were only good for around 450rwhp.
Old 12-18-2013, 11:50 AM
Yes, I agree. I just think it will be quite a while until I reach that level of power. Funds are the issue. I want to go supercharged on flex-fuel eventually. I'm making sure to buy the best components that I can AFFORD for the moment. Like, it made sense to buy the Walbro 400 pump instead of a smaller one because the cost wasn't that much more. I'm struggling a bit with the clutches though.
I'm now considering this clutch:
http://w.ivenue.com/hendrixengineeri...et-slayer.html
For just a wee bit more than an LS7 I can go up in the amount of HP/TQ it will take.
I'm looking at that one too. I'm leaning towards the street slayer though after reading a lot of forum posts and talking to the guy at Hendrix on the phone.
Now, if anyone wants to donate to the "Poor O-Beer Build a car fund" I'm all for that and will install whatever they buy me!
BTW, I got in my old truck this morning to drive into work, pushed in the clutch, started it, took my foot off the clutch, and there sat my clutch pedal; on the floor. I had to do emergency "break away" lubrication to my linkage and the joint about which the pedal rotates. Wisconsin winter road grime is rusting my junk! I was going to be late to work anyway so I adjusted the timing while I had it in the shop.
'69 RS Camaro
