Old 12-18-2013, 04:41 AM
68LS1's Avatar
68LS1 68LS1 is offline
Default Edelbrock Victor EFI Intake - Fuel Rail Options
Does anyone know of any other billet fuel rails to suit Victor Junior EFI Intake
There are the Edelbrock ones, http://www.jegs.com/i/Edelbrock/350/3638/10002/-1
And I believe Aeromotive have one, but it only mentions LS1 & not L92/LS3, http://aeromotiveinc.com/products-pa...fuel-rail-kit/
Looking to see if there are other options
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
Old 12-18-2013, 01:50 PM
carbuff's Avatar
carbuff carbuff is offline
I didn't find any and ended up using the Edelbrock's. The brackets which they supplied to mount them weren't the greatest, so Eric built a set for me. But otherwise they work ok.
Are you looking for a different 'look'?
Old 12-18-2013, 03:10 PM
68LS1's Avatar
Hi Bryan
I didn't like the look of the brackets, look very flimsy in pics. Would also prefer a rounder profile on fuel rail, but not a game killer.
Did Eric keep details on the brackets he built for you?
Merry Xmas
thanks Roger
Roger
Old 12-18-2013, 08:52 PM
carbuff's Avatar
Roger (sorry about the 'd' earlier! I copied SW. ),
I had some painful lessons related to the brackets and my fuel injectors. The Edelbrock intake and rails are designed to use LS1-height injectors, which are 2.5" if I recall correctly. The injectors which came with my engine were 1.5" tall. The u-shaped brackets which come with the rails were too tall for us to cut them down to use with the shorter injectors.
So I scrambled to find solutions. I purchased a set of 'extensions' to adapt the shorter injectors to the taller height, but then I would have had issues with the shaker base. So I didn't use them...
So Eric simply purchased a piece of aluminum u-channel, cut some pieces about 3/4" long, rounded off the ends, and drilled holes in the correct place to mount the rails. About as simple as you can get. I took a couple of pictures tonight, but it's hard to see a lot of details with everything assembled...
Here are a couple of pictures in case they may help:
Old 12-18-2013, 09:38 PM
68LS1's Avatar
Thanks. Good to know. I think I need to use a Bosch EV1 style injector (which is LS1/LS6). Will be running 60lb.
I shouldn't have a height issue, but am planning to run a cowl induction style set up
p.s, nothing wrong with copying SW usually
Roger
