Old 12-23-2013, 04:29 PM
spacepirate spacepirate is offline
Default Can't get lug nuts off
Hey guys,
I can't get 3 off my front lug nuts off because they are stripped. I've tried the gorilla grip socket but can't get it deep enough on the lug to get a grip. I just sprayed some WD-40 on them and gonna let them soak but I'm open to any help or tips!
Old 12-23-2013, 05:47 PM
DTM Racing DTM Racing is offline
Is the nut spinning on the lug or is the lug spinning in the hub?
Old 12-23-2013, 06:39 PM
The outside of the nut is rounded off but I just purchased a nut removal kit from Pep Boys. Going to try it in the morning and hope that it does the trick.
Old 12-23-2013, 08:46 PM
craig510's Avatar
craig510 craig510 is offline
Sometimes you can pound a smaller socket into the nut. We use to use this to remove "locking" lug nuts that were missing the key.
Old 12-23-2013, 09:46 PM
Yeah I tried that and will again but with more love if the special tool doesn't work.
Old 12-24-2013, 12:36 AM
Vince@Meanstreets's Avatar
That sucks, tuner nuts? These aren't on your new wheels are they?
Vince
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-24-2013, 09:45 AM
mitch_04 mitch_04 is offline
I had a similar problem recently. I took a big bolt, welded the front of it onto the back of the lugnut, then put my socket on the bolt. The heat from welding also helps removal.
Old 12-24-2013, 09:48 AM
RBuhr69's Avatar
RBuhr69 RBuhr69 is offline
If you are careful and have enough room or long enough chisel or old screwdriver you can make notches to get the socket or lug not removal tool something to grab on to. Also depending on the wheel if you can get some heat on the stud itself directly, then try to loosen it....Just some thoughts, good luck!
Old 12-24-2013, 01:28 PM
NOT A TA's Avatar
NOT A TA NOT A TA is offline
Make a notch in the face of it with a chisel and use air hammer to spin it. I do it fairly often on rounded nuts or when owners loose the key socket for locking nuts like the round McgGard ones.
John Paige
70 Firebird Esprit, 400 TA clone type "The 14 car"
lab-14.com
Old 12-24-2013, 01:59 PM
pokey64's Avatar
pokey64 pokey64 is offline
I lost the key for the locking lug nuts on my 72 C10. Found a pipe with similar diameter as the nuts and tack welded it on. Spun it loose with a pipe wrench.
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
