Old 12-27-2013, 08:32 AM
no go nova's Avatar
no go nova no go nova is offline
Default Which shifter to use?
What shifter do you guys prefer to use to shift the t56 transmission?
Old 12-27-2013, 06:16 PM
Bad94 Bad94 is offline
I have 3 cars with T56 trans and I run Pro5.0 in all of them,
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 12-28-2013, 06:53 AM
OBeer-WAN-Kenobi's Avatar
I just received my MGW shifter. I haven't used it since I'm still building the car but it gets great reviews and it definitely has a high build quality.
FYI, MGW only sells direct.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 01-12-2014, 05:27 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
^^^^ X1000 ... have used 5.0 in all my cars
Old 01-15-2014, 01:11 AM
gnx7's Avatar
gnx7 gnx7 is offline
Pro 5.0 is a little notchy and can transmit some noise inside the car.
Hurst are cheap and better than stock. B&M Ripper you can't remove the stick.
MGW is the best one I've ever used.
Old 01-15-2014, 08:54 AM
no go nova's Avatar
I went with the MGW from hearing such great reviews along ways from using it tho.
Old 01-15-2014, 11:36 AM
I bolted mine up to my transmission that's still sitting by itself, outside the car. Then I sat on my stool beside it and went through the gears while making "vroom vroom" noises. Seems to be working OK so far....
'69 RS Camaro
Old 01-16-2014, 09:13 AM
no go nova's Avatar
Car crazy are we lol.
Old 01-16-2014, 02:56 PM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Hmm I still have the Hurst shifter... maybe I need to look into the MGW.
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 01-16-2014, 07:24 PM
Sieg's Avatar
Sieg Sieg is offline
I've tried the stock Tremec, White Lightning, and the first-gen Hurst Blackjack and now have the newer gen Hurst Magnum shifter. No complaints at all with the Hurst. Short tight positive throws and nicely machined with quality components.
