Old 12-30-2013, 05:15 PM
brownz brownz is offline
Question 1972 nova ls swap with ride-tech parts?
I would like to know what mounts,headers and oil pan will work with the ride tech tru-turn on a 72 nova. I would like to get a good idea on what works so I can try to locate some second hand (used) parts if possible. I would like to keep the cost down by just using the swap plates and moding the stock auto trans cross member if I can to cut cost but not sure if just the ls swap plates work or not. Also the trans will be a T56 so I know the tunnel will need to be cut.
Brands, part numbers and pics would be great.
Thanks in advance
Old 12-30-2013, 06:54 PM
Bad94 Bad94 is offline
Thanks in advance
whatever headers and mounts the 48 hour Camaro runs.
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
