Old 01-02-2014, 11:05 AM
RoadRace Elco's Avatar
RoadRace Elco RoadRace Elco is offline
Default Steering Question
so i currently have 12:1 gear box in my 66 El Camino, when i am autocrossing it on the turn arounds my arms are all crossed up so i made a call to Lee and they can change the 12:1 to a 9:1 but...they said it will be twitchy
anybody out there running with a 9:1?
1966 El Camino
383 500hp at flywheel
Keisler SS700 5 speed
Mass-Flow Injection
12 Bolt 3:73
Speed Tech full suspension
Ride Tech Coil Overs
Rushforth 18's
Wilwood 6 piston with 14" rotors
Old 01-02-2014, 07:50 PM
Che70velle's Avatar
I've seen 9:1 boxes in Cup cars, but never in a street car. I would think it would be twitchy, to say the least.
Thanks Dad!!
Old 01-03-2014, 12:34 AM
Rod P's Avatar
Rod P Rod P is offline
shuffle steer
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 01-03-2014, 08:32 AM
Sieg's Avatar
Sieg Sieg is offline
I'm running a Lee 12:1 box with a Momo 12.8" Montecarlo wheel and I'd agree with them. If it was a track only car 9:1 would be great but with the condition of modern day roads I think it would be annoying.
What diameter of wheel are you running?
Old 01-03-2014, 11:21 AM
Rod P's Avatar
I have a video of some of our crazy shuffle steering, one with me and one with mike miaer, driving fast is work you have to move your hands, if someone has told you other wise....their wrong
Rod Prouty
Bangshift Stories
Old 01-03-2014, 11:31 AM
Vince@Meanstreets's Avatar
yeah but you look more comfortable than Mike looked. Im sure you have a faster ratio than he does.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 01-03-2014, 04:20 PM
Bryce Bryce is offline
I run 8:1 manual steering in my falcon and I love it. I just added power steering and neither were twitchy and great on the track. I run a little toe out which can pick up the expansion grooves on the freeway.
Old 01-03-2014, 04:41 PM
Twoblackmarks...'s Avatar
Twoblackmarks... Twoblackmarks... is offline
I had and 442 G-body With a Stock 12.7:1 , 2.5 turns Lock to Lock, I think that was brilliant! You only cross hands once With that (usually), I Guess you cant cross them more than once anyway though.. HeHe
I have a Sweet 12:1 in my Pontiac and it also is good for me.
But if you run With toe-in, maybe you want to add less toe-in? Or maybe run With toe-out, that can quicken the steering response vey much, so you get a much quicker turn in. It does not change the steering ratio, but it can dramatically change how the car steers and feels. And if maybe Your problem is too much understeering, so you oversteer on the Wheel more than you optimally would need? If that makes any sense?
If you have not, I would try to change that first. It sure can change alot, if you have not already tried of course..
