Old 01-04-2014, 06:39 AM
dcrider69 dcrider69 is offline
Default 12" wheels on stock width rearend?
69 camaro, mini tubs. Is any body running 12's with a 60"/stock rearend width? I'm sure this requires big back spacing. Interested to hear numbers/facts. Pictures would be great too. Thanks!
Old 01-04-2014, 02:49 PM
hud697's Avatar
hud697 hud697 is offline
Just a wild guess but I'd think around 8-8.5"
Cut the rearend man, looks much better.
Overkill is an often underrated achievement.
1969 Camaro - work in progress
2011 Camaro 2SS/RS A6
Old 01-06-2014, 09:50 AM
garymac69's Avatar
garymac69 garymac69 is offline
I am running 18x12 w/ 8" B.S. on my '69 Camaro with stock width 12-bolt. I have around a 4" outside wheel lip on these wheels, but that amount would be different depending on wheel design.
'69 Camaro - 427 SBC 526hp,593 ft-lbs, Tremec TKO, Ridetech Coilover Suspension w/TruTurn, Billet-Specialties Draft 18x9, 18x12, BFG KDW 275/335
Old 01-06-2014, 01:05 PM
Payton King's Avatar
Default You would use
The stock C6Z06 backspacing to work with that width rear end.
That is what I had on my car. Had rear built 59 inches hub to hub and ran 1/2 spacers on each side...just so I could dial it in for clearance. Total width was 60 inches.
I ran HRE's on mine off of a C6Z06...19x12.5 (stock Z06 is 12 inch width) offset was +53 mm
Old 01-06-2014, 01:09 PM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
That is HAWT!
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 01-08-2014, 03:57 AM
ctski69 ctski69 is offline
GaryMac69, did you have to roll the lip in the rear? Also, what backspace did you run up front? Perfect amount of stagger.....looks great!
Craig
Old 01-08-2014, 10:09 AM
garymac69's Avatar
Yes, I rolled the rear lips 19 years ago when I restored the car, knowing I would always run wide tires. The front 18x9" have 5 3/4" B.S. but would recommend 6" to give a little more clearance on the outside fender lip at full lock.
Old 01-08-2014, 08:48 PM
coolwelder62's Avatar
Around a 8.125 back space should be close with a 60" housing width.Also add your brake /hat thickness to that 8.125 measurement.
Old 01-09-2014, 06:22 AM
Sick! Absolutely love it, will you please share some pictures toward the rear of the car? Thanks!
Old 01-09-2014, 10:37 AM
garymac69's Avatar
I will comply....... These pics were taken when the suspension and wheels were just installed. The car is about 1/2" lower now.
