Old 01-08-2014, 05:24 AM
mustangracer11 mustangracer11 is offline
Default Parts sale
Item Location (City/State):
Ackerman ms
Price:
1000
Description:
Fuel rails for 4.8, 5.3, 6.0, chevy and GMC engines $40
Flywheel for 4.8, 5.3, 6.0 Chevy and GMC $30
Chevy and GMC truck intake 4.8, 5.3, 6.0 $75
69 amx rear glass $250
69 amx quarter window's $50
69 amx door glass $100
69 amx dash pad $40
AMC timing cover and oil pump $50
AMC 727 Transmission $150
MSD Rev limiter pills, $15, 9100-9900 RPM's
MSD REV limiter pills $15 8100-8900
spec stage 2 11 inch clutch for ford very low miles zero heat spots. $250
Ford modular bellhousing for tremec transmission's $300
2003 Ford F-150 ABS $50
2003 F-150 windsheild washer fluid jug $25
2003 Ford Lightning Intercooler Coolant Tank $40
4R100 Transmission Input shaft $50 from 2003 lightning
F-150 battery Tray $25
1988 or 89 mustang Gauge Cover and light switches $40
V-8 explorer headers $45
V-8 explorer flywheel $15
Moser C-clip eliminator For ford 8.8. One new one is used. $80
87-93 mustang lights one new one used New one is for right side $20. Used one is for left side $10
Fox body mustang 5.0 injector harness. $40
Fox body mustang fog light $25
2 right side headlights for 87-93 mustang, $15 for older looking one, $20 for the better one
Oil cooler from a 95 cobra will fit other 5.0 cars $30
5.0 mustang water pump pulley and crank pulley $10 each
Exhaust manifolds for 4.8, 5.3, 6.0, chevy and GMC truck engines $50
Transmission pan for 4R100 ford $30
Fox body mustang stock radiator $45
Detroit engine Timing pin and valve adjustment tools (will post price soon)
Ford f-150 wheels 2 16x8's, 2 16x10's $150
Fox body 5.0 5 speed bellhousing $50
3 tires 275/50/20 Goodyears $30 each or $75 for all 3
4l60e transmission $200
13x7 4 lug steel dirt track wheels and hoosier tires $15-50 each depending on condition .
mustang clutch quadrant and firewall adjuster I don't remember the brand $15 each or $25 for both
4 quad shocks $5 each
Quad shock mounting bracket left and right $5 each
Caterpillar C-15 3406 exhaust gaskets 2818261 $100
Caterpillar Sensor 1946725 $100
Caterpillar Sensor 2644297 $25
Caterpillar Gasket kit 3634540
Caterpillar Gasket kit 2101991
Caterpillar Crankshaft seal 1425867
3 electric fans unknown brand doesn't come with any mounting hardware $15 each
Old 01-08-2014, 10:34 AM
jwcarguy jwcarguy is offline
Banned
pm sent
Old 01-08-2014, 05:27 PM
jovozx12's Avatar
jovozx12 jovozx12 is offline
Originally Posted by jwcarguy View Post
pm sent
You don't need anything Jeff. Let me buy something.
Jerry
Old 01-08-2014, 09:41 PM
CarlC CarlC is offline
What s the LS computer and harness from/type?
http:www.vaporworx.com
Old 01-09-2014, 05:13 AM
CornHusker4Life's Avatar
CornHusker4Life CornHusker4Life is offline
Bump for honest seller. I purchased a shifter and it was exactly as described and shipped promplty.
Old 01-09-2014, 07:48 AM
The harness was custom built for a twin turbo ls1 in a 70 camaro set up for speed denisty the computer is from a 01 camaro and has hp tunning software on it. I bought it from LS1 tech a few years ago and have never used it.
Old 01-09-2014, 09:29 AM
1nastyZ06 1nastyZ06 is offline
I am interested in the rails and tb. What size tb? And what color are the rails?...black or silver?
Old 01-09-2014, 09:34 AM
Old 01-09-2014, 10:08 AM
They are black. I'm not sure on the tb size it came on a 2004 lq4
Old 01-14-2014, 05:25 PM
Bump.
