Old 01-15-2014, 09:33 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Default Ridetech coilover/air suspension packages for 05+ Mustangs
We've just released our new coilover and air suspension lines for the 05+ style Mustangs! The designs feature a steel, monotube, Fox Racing strut with a billet aluminum mount. In the rear, we use our aluminum, threaded body, monotube shocks with the sleeve type bellow or coil spring. The ride quality and and handling of the new Mustangs can be greatly improved over the stock suspension.
Compared to the factory height, both systems designed to lower the car about 2" at ride height. With the air suspension, there is the ability to lower the car about 2" lower than the ride height.
Each kit great changes the handling ability and the comfort of the ride, the difference between the two, is simply, a personal preference. We use the same shocks and struts internally on both systems. The only decision that has to be made is whether or not you want the car to be slammed on the ground in a parking lot or sitting at a static ride height!
Ride height:
Lowered stance:
They are offered in packages as well!
Just like all of our other shock packages, they also come with a 1,000,001 mile warranty!
