Old 01-15-2014, 07:03 PM
rsimons rsimons is offline
Default What sway Bar with Wayne Due subframe?
I have a 67 Firebird with a Wayne Due C4 subframe. The subframe was installed when I got the car. The sway bar that is on it is too narrow and rubs the outside of the frame rails. Does anyone know what sway bar is supposed to go on that subframe? Any advice is greatly appreciated.
Old 01-17-2014, 12:21 AM
Vince@Meanstreets's Avatar
Can you post pictures of both ends? I had a similar issue and found the bar was not staying centered. I welded a pair of rings on the bar to act as bushing stops to keep the bar from creeping left and right.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-18-2014, 01:26 PM
Here are some pictures. I don't think it is a centering issue because it is tight on both sides.
