Old 05-09-2006, 02:01 PM
Mike Hall's Avatar
Mike Hall Mike Hall is offline
Default 66 nova HT
66 nova HT with a running 283/powerglide which looks to be all original. Car runs but will not move. The car has rust all over but nothing to bad it cant be repaired. The worst of the rust is on the firewall behind the fenders where the front clip bolts on. There is also rust that was covered with bondo on the lower quarters that would be easy to fix. Once fixed you would not see any repair work from inside the trunk. The trunk has some holes but is not totally rotted out. The floors are solid other than where the floor comes up to the firewall which has some holes. The front fenders are slam full of bondo but I have a workable set of fenders that go with the car. I almost forgot but there some rust holes around the rear glass but I feel that it could be fixed without to much work. The car is complete for the most part with a complete drive train and complete interior.
$5000 Firm with engine/trans
$4500 Firm without engine/trans
Mike
[email protected]
229-400-3993
