Go Back   Lateral-g Forums > Help, Feedback and Testing > The Skid Pad: Test your posting skills
Old 01-21-2014, 02:31 PM
KPC67's Avatar
KPC67 KPC67 is offline
Default Imbedding
Kevin Carter
Old 01-21-2014, 02:40 PM
OBeer-WAN-Kenobi's Avatar
Originally Posted by KPC67 View Post
[YOUTUBE]VxvAkUupnKwYOUTUBE]
You missed a "[/"
Try this:
"["YOUTUBE]VxvAkUupnKw[/YOUTUBE"]"
Remove the "
P.S. to the mods........why don't the CODE tags work? It still tries to embed a video with:
Code:
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 01-21-2014, 05:09 PM
camcojb camcojb is offline
Originally Posted by OBeer-WAN-Kenobi View Post
You missed a "[/"
Try this:
Remove the "
Code:
The first post he's missing the [/ on the right hand youtube. The two in your post have " inside the brackets which won't work. It works as below as you said when you remove the " out of the code.
Old 01-21-2014, 06:37 PM
I know. I was trying to show him how it worked but I couldn't use the code tags because THEY don't work. So I was forced to use the quotes.
Why don't the code tags work? They should ignore any code inside them so that you can show the proper code to others without the code actually working like above.
'69 RS Camaro
Old 01-21-2014, 06:53 PM
no idea, never tried using them.
Old 01-21-2014, 07:25 PM
Rod P's Avatar
Rod P Rod P is offline
ha ha ha ha ha ha ha ha ha
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 01-22-2014, 08:32 AM
Maybe it's a setting? Maybe the [YOUTUBE] tags need to be added somewhere so that it ignores them as well
It works with smilies
With code tags:
Code:
:bump: :walkingdog:
Without code tags:
'69 RS Camaro
