Old 01-26-2014, 07:37 AM
7firebird1's Avatar
7firebird1 7firebird1 is offline
Default Need motor mounts for 71 Firebird LS swap with TKO 600
Hello all! I am in need of a set of motor mounts for my 71 Firebird that I am dropping an LS engine in with a TKO 600. Not sure if I want it in the standard location or forward or set back. The car is going to be more of a mild pro touring car. I have also heard that the tunnel needs modified with the installation of the 6 speed. Anyone out there in G Land have any suggestions? Thanks in advance!!
Old 01-26-2014, 04:03 PM
glassman's Avatar
glassman glassman is offline
I'd use the entire Holley/Hooker setup, i did and everything fits good. My headers are a little low for my liking but we're working on a solution for that.. But i'm not sure how the crossmember would fit up as those are design'd for a t-56. There are some good posts on NastyZ28 (which is a 2nd gen Camaro forum) but your info for that would be the same....good site with a load of good info....
Mike
Old 01-26-2014, 04:40 PM
7firebird1's Avatar
Thanks Mike! How low is your car? I want mine to sit as low as possible and still be drivable.
Old 01-26-2014, 06:08 PM
glassman's Avatar
My car is slammed, well pretty low, the headers sit 2.375 at there lowest point, which is fine....
Mike
Old 01-26-2014, 06:47 PM
7firebird1's Avatar
Sweet!! That sounds about right to me. Thanks again Mike.
Old 01-26-2014, 07:26 PM
jeremy30thz's Avatar
jeremy30thz jeremy30thz is offline
If you decide to use Stainless Works 2nd gen LS swap headers they come with the correct engine mounts. If you would like me to price a set for you shoot me a PM
Old 01-27-2014, 02:00 PM
mikespeed95 mikespeed95 is offline
Glassman, any photos of your engine bay? I tried to sift through Nasty....not much luck.
Which Holley mounts did you use? I don't want the engine sitting too far forward.
Mike Peters
Bookface page with car stuff
Youtube page with car stuff
1970 Camaro - hardmounted jackstands and flash rusted steel hopes and dreams.
Old 01-27-2014, 02:16 PM
CamaroMike's Avatar
CamaroMike CamaroMike is offline
I notched my crossmember so I could sit low enough and give the pan plenty of clearance. I made my own mounts for the engine and trans, took a few hours but was worth it.
Alabama
1969 Camaro
1978 Camaro
Old 01-27-2014, 02:19 PM
CamaroMike's Avatar
Alabama
1969 Camaro
1978 Camaro
Old 01-27-2014, 07:43 PM
7firebird1's Avatar
I don't have a crazy budget, so I am trying to go as thrifty as possible.
