seamless vs welded stainless tubing
01-30-2014, 08:22 AM
Efi69Cam
Looking to order some tubing to finish up my fuel lines.
Can I use .020 wall annealed welded tube if I'm going to 37' flare it, or do I need thicker wall?, seamless?
Efi69Cam
Find all posts by Efi69Cam
2
01-30-2014, 12:05 PM
dontlifttoshift
You need seamles tubing, welded tube will have booger on the inside and you will _never_ make it seal.
I usually use .035"
Donny
dontlifttoshift
Find all posts by dontlifttoshift
3
01-30-2014, 02:56 PM
Efi69Cam
Thanks. seamless it is, I do need it to seal.
Efi69Cam
4
02-05-2014, 08:09 PM
bentfab
Doing it home with .028 wall it will most likely collapse on you in the middle of a bend. I sell and use .035 wall seamless tube.
Give me a buzz at the shop tomorrow and I can help you out with any questions or help guide you in the rite direction
Mark
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
bentfab
Visit bentfab's homepage!
Find all posts by bentfab
Linear Mode
Switch to Threaded Mode
06:41 AM
