Old 01-31-2014, 01:57 PM
SuperB70's Avatar
SuperB70 SuperB70 is offline
Default Bad PCM?
Hi, I've been doing an LS1/4L60e swap to my customer '71 Buick Skylark convertible.
He had already bought an '02 Camaro engine, trans and it came with stock harness and pcm.
Well , We chanced the harness to painless kit and did everything as the install manual tells to do. Not so difficult thing to do. Car has an extra protection so had to install extra relay to controls feed to fuel pump but thats no brainer and has nothing to do with this.
I do know my way in car electric stuff..
So today I try'ed to get it running. Right after I turned battery on, it burned pcm/ diagnostic constant fuse. And I dont have keys turned on yet.
So at that stage there should not be any thing happening at the PCM, just standby current, after ignitionkey is turned then it should come to life.
My diagnose it that I have a bad PCM.
Anybody have any other ideas?
, Juhani
Old 01-31-2014, 07:57 PM
INTMD8's Avatar
INTMD8 INTMD8 is offline
My guess is the harness is shorted to ground somewhere.
I suppose anything is possible but I've never seen a PCM with an internal issue causing an issue like you describe.
69 Charger. 438ci Gen2 hemi. Flex fuel. Holley HP efi. 650rwhp @7250 510rwtq @5700. 95 F355. 96 Carrera 4S. 59 Cadillac series 62 convertible.
Old 03-11-2014, 02:35 PM
SuperB70's Avatar
Just updating that my diagnose was right.
Just got a new reflashed ECU from Street and Performance today.
Connecting it to wires and engine fired right up..
Thanks Mark (Campbell) for great service and fast shipping.
, Juhani
Old 03-16-2014, 05:10 PM
driveability driveability is offline
Interesting the PCM was shorted via long term memory / 12 volt constant. Being an old tune up guy I would make sure something isn't flashing to ground. If that happen to me I would poor over the harness moving things around even just slightly could have corrected that situation temporarily.
Just me but otherwise FANTASTIC !!!!!!!
