Old 02-02-2014, 07:26 AM
mnm99 mnm99 is offline
Default How much is involved in a LS7 swap?
I have a 68 Camaro and looking to do something different or maybe just sell. How much is involved in just swapping out the 350 for one of these? Trans ect...
Old 02-02-2014, 12:14 PM
https://lateral-g.net/forums/showthread.php4?t=44878
https://lateral-g.net/tech_articles/LS7_install/
And lots of more under search button.
63 Z06
Old 02-03-2014, 04:16 AM
Originally Posted by Bowtieracing View Post
Old 02-03-2014, 05:20 AM
67Rally's Avatar
67Rally 67Rally is offline
You can make it as simple or as complicated as you want, but a big part of it depends on what you plan to re-use from your current setup.
Is your radiator up to par? Will you re-use your current transmission. Will you convert to hydraulic clutch? Will you modify the existing wiring harness or buy a new one? Do you already have EFI, or will you need to modify your existing tank/buy a new one, etc...
Old 02-03-2014, 02:40 PM
Yea it looks like a lot of work. I'm on the fence with keeping the car and upgrading the motor or sell and get another car all together...I'm all confused....
Old 02-03-2014, 02:42 PM
im4u2nvss im4u2nvss is offline
Most people that swap to LS motors are very happy with the results.
Old 02-05-2014, 09:27 AM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Hoping to finish up my LS3 swap this week (waiting to tie up loose ends and tune).
CANNOT WAIT! Been down since November.
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
