Old 02-02-2014, 10:02 PM
Damn True's Avatar
Damn True Damn True is offline
Default Looking for reviews on the LSX376/525
Considering this engine for my project.
Wondering though if it pulls enough vacuum to support power brakes? Not sure if I'll run them but I want the option.
How radical is the idle?
Does it require a fairly open exhaust to be "happy" or will it be ok with an exhaust on the quieter end of the spectrum? I don't mind a bit of lope and rumble but I get along well with my neighbors and Id like that to remain the case.
Any low speed drivability issues?
From what I've read, it seems they benefit from a tune. Apparently many feel the GM controller is off to the rich side. Is this an issue with the early releases that has been rectified or is it still the case?
Thanks!
Old 02-03-2014, 08:24 PM
fishface's Avatar
fishface fishface is offline
Hey Mike, could you give us some input on the post below about the ls3/525? Kinda wonder the same thing about driveability/ idle quality etc. Thanks!!
Old 02-04-2014, 05:54 PM
Mike Norris Mike Norris is offline
Supporting Vendor
I can but I do not see a thread link.
Mike
Mike Norris Motorsports
Raymonds Performance
3828 Clarks Creek Road
Plainfield, IN 46168
407-616-2518
www.mikenorrismotorsports.com
[email protected]
Visit Our Facebook Page
Old 02-04-2014, 06:01 PM
Supporting Vendor
If it is about the 376/525 crate using the ASA cam, that cam is a 226/236 on a 110 LSA. This has 11 degrees of overlap which is not crazy but aggressive and will have a choppy idle and buck at low RPM speeds, especially in an manual trans car.
It is close to the cam I use except I put it on a 114 LSA and overall 2 degrees of overlap. Sounds awesome and drives nicely.
Bottom line, at least for me, I would not use an ASA cam for a street car. Hope that helps.
Mike Norris
407-616-2518
[email protected]
Old 02-04-2014, 06:53 PM
Damn True's Avatar
Is nobody running this engine? That doesn't give me a warm/fuzzy feeling.
Old 02-04-2014, 08:57 PM
fishface's Avatar
Check out the Mike Norris thread below. I asked about it for you as I had the same questions. Figured he would know if anyone. Lol
Old 02-04-2014, 09:16 PM
Wissing72's Avatar
Wissing72 Wissing72 is offline
I won't know for another month or so until mine gets finished. I am running the 525 ls3, I have heard them but only for a minute. They sound really good. My builder has used them before and his customers are very happy with them, sorry I don't know what specs for exhaust etc. yet.
Chris
70 Chevelle. Roadster Shop Chassis, The shop llc/ Jon Lind interior LS3/6speed. Thanks to Precision Classics and Collision Eugene, Or. http://precision-classics.com/
Build thread:https://lateral-g.net/forums/showthread.php4?t=39517
Old 02-04-2014, 10:26 PM
Damn True's Avatar
Here is the thread he was referring to: https://lateral-g.net/forums/showthread.php4?t=44957
Good info on the 525. Thanks. Sounds like the 480 variant might be a better call. If I want more power later I can add a more sophisticated cam and tune to it right?
Old 02-05-2014, 05:30 AM
Supporting Vendor
I m not a big fan of the "Hot Cam" either, but definitely more street-able then the ASA cam. Just remember that both the 480 and 525 engines come with stock beehive springs and will require a good upgrade there also if changing cams. The reason being that the ASA and Hot Cam both have lifts of only .525" and those heads can easily use .600" lift.
I would be tempted to just get a stock LS3 engine, but the cam swap would need more parts (change timing gear & bolts, damper), but could be less expensive in the end and make it more "your" engine and not a cookie cutter. And please do not judge a "good cam" or "awesome cam" on idle sound alone. It does not take a lot of cam to get that sound. and a lot has to do with tuning.
Hope that makes sense.
Mike Norris
407-616-2518
[email protected]
Old 02-05-2014, 05:39 AM
fishface's Avatar
That will be interesting to see what your impressions are. I am starting to think personally when the time comes I will order a stock Ls3. For the difference in price I can do a cam/springs as well as trunion upgrade and pushrods. I am looking for something with a milder idle. Have been looking at the Katech Torquer cam.
