Closed Thread
Old 02-03-2014, 04:29 AM
mnm99 mnm99 is offline
Default 1968 Camaro Convertible ...Twin turbo...
Item Location (City/State): Miller Place , NY
Price:$39,999
Description:One of a kind. Time has come to sell. Moving on to another project..
Will take a fair trade for a 65 Shelby Cobra ( replica )
Just a note...Currently the car is under a small make over. I'm redoing the entire dash. Repainting metal dash, all new bezels, new visors, dash pad, ignition key, steering column ext... Just a fresh up. will be ready in about 2 weeks.
I'd like to note I DO HAVE THE MATCHING NUMBERS 327CI DRIVE TRAIN THAT GOES WITH THE CAR AND EVERY PART IT ORIGINALLY CAME WITH......I'm sure I missed a bunch in the list that was done to it also..
The car was never raced or brought to the track. Only car shows. I wanted to do something different. How many Big block Camaros are out there? How easy is it to bolt on a Supercharger? Now..How many TWIN TURBO Convertibles have you seen?? That's why I did it...People are in Awww when they see it. Enjoy
ENGINE / TRANS / COOLING / EXHAUST
- GM 350 Crate
- 4 Bolt mains
- 8.25:1 compression
- Melling 10555 HV oil pump
- Performer intake
- March Billet Serpentine belt system
- Weiand High flow Aluminum water pump
- Billet valve covers
- EVAC air pump system, 1 PSI activation
- Custom built T350 transmission
- CUSTOM built PTC 3000 stall converter
- 4 row CUSTOM radiator
- SPAL dual fans
- Ford 9" rear, 3:25 posi, Moser axles
- Full 2 1/2" exhaust with warlock mufflers.
- Dual Electric cutouts.
- Hotchkis full suspension
- Hotchkis frame connectors
- Caltrack traction bars
FUEL SYSTEM
- Glens Performance Sump tank with baffles
- Full ½ Stainless steel hard line used for Feed and Return
- Stainless Teflon line from regulator to carb, Fuel line and gas tank sump
- Bosch 044 Fuel pump
- Aeromotive 10 and 100 micron pre and post filters
- All Stainless steel fittings
CUSTOM TWIN TURBO SYSTEM
- Twin Garrett T60-3 Turbos ( Running 6 PSI of boost ) These turbos are capable of 475hp each.
- Twin 44mm Tial blow off valves
- Custom 304 stainless tubing all Ceramic coated in and out
- Holley Blowthru 750. Custom built by CSU powder coated silver
- Polished Extreme Velocity bonnet
- Twin K/N high flow filters with Custom intakes
- Manual boost regulator
- System has custom supports to relieve stress on the headers
Electronics
- All Autometer gauges, Fuel, Water, Oil , A/F, Fuel Pressure, Boost/Vac, Trans temp, oil Pressure,
- MSD 6AL2 Programmable box
- Dakoda digital Programmable fan temp controller
- Innovate Wideband LMA-3 controller
- Odyssey PC1500 battery
- Electric system cutoff switch
- Line lock system for brakes
- Custom shift lights
Sale or possible trade. If serious Email me at [email protected]
Old 02-03-2014, 08:07 AM
cwylie cwylie is offline
Ever been on the dyno?
Old 02-03-2014, 11:00 AM
No. Never on a dyno. I tuned it myself with a 13.6 A/F at idle and 11.2 at WOT. Gets to full boost at around 2800 rpm. Boost comes on pretty fast and with a 3000 stall it's lot's of fun.
Old 02-03-2014, 04:44 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Looks like a killer "sleeper". Nice car.
GLWS
Old 02-04-2014, 01:57 PM
GLWS
Shhhhh...LOL
Old 02-05-2014, 10:56 AM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Sleeper to say the least! Nice build. GLWS
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 02-07-2014, 02:05 AM
More pictures
Old 03-16-2014, 04:32 AM
Price reduced $39500....
Old 03-23-2014, 07:38 AM
Some videos..
Will add soon....
Old 03-23-2014, 03:21 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Wow...that car is just stupid clean! GLWS
Curtis
Closed Thread
