Old 02-03-2014, 03:20 PM
Default BMW wheels on a Camaro
I've heard that BMW wheels can fit on a 69 Camaro wheel hub. A Camaro has 4.75 bolt pattern and the BMW has 4.72. I was told that they can be used . I'm looking for wheels and tires to roll my project around on but I need 18" to fit over the brakes. I also heard that the BMW's are hub centric. Can they be fit on some how?
Please any one who has done or heard if this will work please chime in.
Thanks!
Old 02-03-2014, 09:25 PM
Vince@Meanstreets's Avatar
Thanks!
To do it properly you would need to run wheel adapters. Its close but the lugs are tight in the wheels. Either the rims or studs will get buggered up after time.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-04-2014, 01:32 AM
ADiCarlo ADiCarlo is offline
Take the wheels to a shop and get them re-drilled for 5x120.56 (5x4.75) from the factory 5x120.
The difference in minor so inserts won't be needed but the lugnuts will have a proper seat and be able to be torqued correctly with even pressure.
In regards to hub centric you'll need hub centric rings and the size will depend on what hubs your running.
Old 02-04-2014, 06:03 AM
Rick D's Avatar
Rick D Rick D is offline
Waynie, if you are just using them for rollers they will work fine, I have done this in the past to clear big brakes. Just be careful when putting them on and off to not hit the threads on the studs.
Rick
Old 02-04-2014, 04:38 PM
intocarss's Avatar
No they don't get buggered up. I ran them on my old camaro for 2 years
The difference is 5x120mm (BMW) and 5x120.7mm(GM) I've seen cheapo chinese wheels that were farther off. Yes the 100% correct way is to use a adapter, but many have done it w/o and have no issues.
Old 02-05-2014, 01:13 PM
Thanks .
Old 02-06-2014, 05:14 PM
GeoffP GeoffP is offline
I have BMW Beyern 5's on my car. No problems through several events and about a year's use so far. Just make sure they're properly torqued. I have had zero issues with mine coming loose or any of the other problems many people say they will cause. It's important to know that my car has 1/2 ARP lug bolts front and rear.
GeoffP
68 Camaro LS1 T56 3.55 12 bolt posi
Old 02-06-2014, 10:01 PM
thanks I have 1/2" studs too.
Old 02-07-2014, 07:51 PM
renegade6 renegade6 is offline
Check this out, may be helpful. http://www.thirdgen.org/techboard/wh...t-pattern.html
63 Biscayne
Schwartz Performance Chassis
Build thread: https://lateral-g.net/forums/showthread.php4?t=37302
Old 02-10-2014, 09:16 AM
67Rally's Avatar
67Rally 67Rally is offline
Agreed, I've looked into BMW wheels as well. The GM pattern is 5x120.65, so an even smaller difference. But let's say it's .7mm.
To get a visual on that, grab a mechanical pencil and give it a few clicks. The lead is probably .7mm thick. Now shave it in half so it's only .35mm thick. That's the difference in hole spacing we're talking about.
Most aftermarket wheels are not hub centric either.
