Old 02-04-2014, 11:38 PM
pimlico pimlico is offline
Default T56 + LS9 - what clutch?
Hi all,
Does anyone here have a T-56 and LS9 engine?
What clutch kit are you using?
Old 02-05-2014, 12:41 AM
Vince@Meanstreets's Avatar
Spec performance
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-05-2014, 10:54 AM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Dont have an LS9, but do have a 416 LS3 and going to throw boost at it later this year... I have a McLeod RXT.
Had an RST before the LS3 swap (had 350 before) and loved it.
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 02-05-2014, 01:25 PM
ironworks's Avatar
My not the factory LS9 clutch? I believe it even comes on the crate engine. It works pretty well and is a dual disc unit.
Old 03-04-2014, 07:16 PM
forcepower forcepower is offline
check out monster clutch co
Old 03-04-2014, 07:22 PM
Che70velle's Avatar
This. The factory ls9 clutch is a great unit, and is used by many for performance builds, a couple of which are on this forum.
Thanks Dad!!
Old 03-04-2014, 11:37 PM
gnx7's Avatar
gnx7 gnx7 is offline
I've driven many McLeod twin discs (RST and RXT) and love them.
If you are going to be doing full on launches at the strip/street on slicks/sticky tires get the RXT. If you aren't the RST should be able to handle around 800hp depending upon the weight of your car. My buddy runs the RXT behind a turbo LS9 making 960rwhp+. The car is only 3000lbs with him in it.
