Old 02-07-2014, 07:27 PM
TK442 TK442 is offline
Default 442 swap out rear end
What other rear end would fit under 1977 cutlass 442 that would have disc brakes and would be a bolt up a go situation I'm putting a LS motor in the car.
Old 02-08-2014, 09:36 AM
ProTouring442's Avatar
The rear out of a 94-96 Impala SS should fit (it's essentially the same chassis), but there are myriad kits out there to put discs on the rear that is currently installed in your car.
The rear in your car should be a corporate 10 bolt. If so, it's damned strong. Add a posi, and a nice disc kit, and you're golden.
Old 02-09-2014, 12:05 AM
Ok thanks I talk to wilwood at this time they do not make disc brakes for this rear end thats in the car because it has a pressed on bearing but they did go on to say they have a kit coming out in two months I talk to them four different times about this. So thats why I was asking about a different rear end and I thought it might be cheaper to go this route. Thanks for the info
Old 02-09-2014, 05:48 PM
This looks pretty promising...
http://www.nastyz28.com/forum/showpo...5&postcount=63
It's from this thread: http://www.nastyz28.com/forum/showth...16#post1743916
Old 02-10-2014, 10:50 PM
I cant see the pictures
Old 02-11-2014, 06:00 PM
Try here: http://www.nastyz28.com/forum/showthread.php?t=109454
I'm not a member of that forum, I just did some searching and come up with it, so if i can see them, I would think you should be able to.
Old 02-11-2014, 10:59 PM
I can see that thanks alot I dont know why I couldnt before
Old 02-11-2014, 11:00 PM
What year 442 do you have
Old 02-12-2014, 04:23 PM
Me? I am building a '72 'vert.
454/port injection
Richmond 5-speed
C6 Z06 Brakes
4-Wheel independent suspension
Lots of other stuff...
Old 02-12-2014, 08:16 PM
454/port injection
Richmond 5-speed
C6 Z06 Brakes
Thats sweet how much more until it's on the road turning heads
