Old 02-13-2014, 09:53 AM
hotwired's Avatar
hotwired hotwired is offline
Default Holley HP PMW Cooling Fan Control
Ok so I was reading on another post on here using the E67 for PWM fan control and the Vette #15-80803 controller and it got me thinking.
I am installing the Holley HP efi on a customer vehicle with a boosted LS7, and it has a single cooling fan.
Checking the outputs I am able to set up a -(low) PWM set to a fixed frequency or 128Hz. I set up a table using MAP and CTS for the x and y axis and table units with duty cycle so that the fan could ramp up for both temp and boost pressure.
Input triggers set at:
RPM activate above 450 (so will only come on with engine running)
Temp activate above 170 (so fan starts at 25% and will ramp up to 95% by 195)
VSS deactivate above 60 MPH
Any thoughts? I have not installed or attempted yet but appears it should work?
68 Buick GS 400
74 Buick Apollo turbo 6 project GSiX
67 Buick Lesabre SOLD
65 Buick Skylark Droptop
83 Buick Regal bracket car
Anyone see a pattern?
MSD "Wire to Win" winner 05
http://hotwiredcustoms.com UNDER CONSTRUCTION
"The Truth is Every man Dies, not Every man LIVES"
Time, Money, Quality...what can you afford to sacrifice
Old 02-21-2014, 10:55 AM
hotwired's Avatar
Lots of views and no comments ? Has anyone done this with any other PCM other than OEM? Willing to try was just hoping for some encouragement.
68 Buick GS 400
Old 02-21-2014, 12:01 PM
hifi875's Avatar
hifi875 hifi875 is offline
my holley ecu had a fan output 2 actually. I just hooked up my fans and programmed into the ecu as to what temp they come on.
Old 02-21-2014, 12:35 PM
carbuff's Avatar
carbuff carbuff is offline
Yes, that works, but he is specifically asking about the PWM functionality to run the fans at slower speeds. I have an HP EFI installed, but did not try to use that functionality. I would love to get more information on doing this also...
Old 02-21-2014, 02:47 PM
hifi875's Avatar
I had a spal pwmv3 or whatever before I got my efi and that thing worked good when it worked, but half the time it defaulted to fact and would lose programing and I didn't like it at all.
Old 02-21-2014, 07:22 PM
hotwired's Avatar
another option in place of the gm controller:
http://www.amazon.com/gp/product/B00...g=vglnk-c58-20
anyone have experience with these?
might need to 2 wired in parallel to handle the amps.
Also not sure what Hz to operate them at.
68 Buick GS 400
Old 02-21-2014, 07:24 PM
snappytravis's Avatar
I emailed holley a few weeks back on this same issue with a f5 controller. They pretty much said run it by itself, It is a pwm type controller. I believe if you try to run it the way you are wanting to you need to use two relays. I think they can be triggered. Let me know what you come up with.
Old 02-21-2014, 07:32 PM
hotwired's Avatar
What Holley are you running?
68 Buick GS 400
Old 02-21-2014, 08:47 PM
Holley hp ecu with a ls3. Go to the holley forum, I see your on there already. Go to page two and about the 15th post down is one I put on there see if there is anything that helps. I think the amp draw is to much?
