Old 02-16-2014, 07:14 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Default Al Knoch Door Panels 1969 Camaro
Has anyone used the Al Knoch Deluxe door panels for a 69 Camaro?Just wondering if the quality was better than OER or other brands,thanks for any help.
Old 02-16-2014, 08:22 AM
Musclerodz's Avatar
they are nice, only ones I use for deluxe door panels.
Mike Redpath
Musclerodz & Customz
facebook page
Old 02-16-2014, 02:47 PM
tubbed69's Avatar
Thanks Mike,that's what I will get.
Old 02-17-2014, 09:24 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
What Mike said
TRACY WEAVER
www.recoveryroominteriors.com
Old 02-17-2014, 11:19 PM
fishface's Avatar
fishface fishface is offline
I am sure you guys would be the ones to know. I gave read numerius threads that they can be a pain to fit but no complaints about the quality. Do you have any tips on installing them? Some have said a heat gun helps but sometimes edges need trimmed a little.
Old 02-18-2014, 09:31 AM
JKnight JKnight is offline
Has anyone ever encountered issues with aftermarket 69 deluxe panels being too thick? I removed my factory drivers side panel and tried to put a new one in it's place; the aftermarket version had to be 3/4" thicker than the factory one I removed. Good luck getting a window crank on with that!!
I just want to make sure the next set I buy are decently faithful to the original panel.
Old 02-18-2014, 12:10 PM
tubbed69's Avatar
Do you know what brand it was that you bought?
Old 02-18-2014, 01:07 PM
Can't be sure. They were second hand via Ebay, not from the original distributor. I don't suspect they were Al Knoch brand, just wondering if anyone else had ever seen that issue.
Old 02-18-2014, 02:55 PM
tubbed69's Avatar
were you replacing deluxe door panels or did you have standard before because deluxe door panels do take a different window regulator
Old 02-18-2014, 03:04 PM
I was replacing the factory deluxe panels. I've verified it has the deluxe regulators just as a sanity check. I'll have to take some pictures for ya.
