Old 02-21-2005, 10:35 PM
Musclerodz's Avatar
Default LT-1 and ZF-6 speed 4 sale
I have been wanting to do a LSX motor for a while now and I need to buy lots of drivetrain parts so I figure if I can sell my LT-1 setup, I can kill two birds with one stone. LT-1 was built by Boyd's Racing Engines in Norman, OK 2 years ago and pickled. I have run the numbers on a dyno sim and comes in around 400 hp. Here is the specs:
'95 Block bored .030
Crank and rods stock
Crane cams equivilent of GM Hot Cam
11.1 hyperuretic (sp?) pistons
aluminum heads were flowed, very close so they were not touched
1.6 roller tipped rockers
rail & injectors cleaned and two replaced
new water pump
new optispark
stock accy drive dressed and painted
new tensiometer
stainless bolt kit
naturally all new Fel-Pro gaskets, bearings, oil pump, etc.
Bosch Platinum +4 sparkplugs
MSD 8 mm wires
new bellhousing and clutch fork
low mileage very clean '96 ZF 6 speed
It still needs the following items:
clutch, press plate, throw out bearing
clutch master and slave cylinder
'93 computer reprogrammed
MSD 6A ignition box
throttle body bored to 52mm
wire harness
accessories
I don't think I missed anything, but I might have. I would rather the motor go to a good home than sit here another year. Boyd's builds some of the best engines here in OKC area. I have near $6500 in motor and tranny to date. I have around $4500 in receipts not includding tranny or motor core. I am missing a few receipts. If you are serious and would like to make an offer, please PM me and we will talk.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
