Old 02-24-2014, 12:45 PM
paulk68 paulk68 is offline
Default removing coil spring
I pulled out my 68 camaro subframe to be dismantled (it is sitting on jack stands) and am wondering what is the safest way to get the coil springs out? do i need to compress them,then pull the upper and lower control arms?
Old 02-24-2014, 01:18 PM
OBeer-WAN-Kenobi's Avatar
I just did this last weekend and my answer to the problem was to let someone else (my uncle) do it. LOL
Seriously though, you can remove the uppers first to get them out of the way. After that, the safe bet would be a spring compressor. Compress the spring and remove the shock which is at that point, basically holding the spring in and pinching it in between the spring cup and the lower control arm.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 02-24-2014, 01:56 PM
Sieg's Avatar
Sieg Sieg is offline
Here's one example:
Those internal compressors are a PITA, especially if you're working with aftermarket (shorter and thicker wire springs) they should work ok with stock coils. I gave up trying to get mine to work on the Hotchkis springs in the sub I was disassembling. The I strapped my frame down to the utility trailer side rails it was sitting on and put my small floor jack under the control arm and popped the ball joint. The shorter spring makes this possible but you're still dealing with stored energy and a heavy spring. Be careful.
