Old 02-24-2014, 07:58 PM
70Nova's Avatar
70Nova 70Nova is offline
Smile F/S Miscellaneous from the Garage
Item Location (City/State):
Parts located in Upstate South Carolina
Price: Individually show below
Description:
Two fabricated dash panel inserts. They are slightly larger than will fit my application. 16 gauge steel with black oxide coating. Speedometer and Tach holes are sized for Autometer 5" gauges. Smaller gauge holes are for 2 5/8" gauge sizes. Gauges not included.
$40 each plus shipping
March 624 GM Saginaw Power Steering Pulley 6 groove serpentine for a 0.75" bore press-fit shaft design. New, never mounted. Price at Summit $75.97
$45.00 plus shipping
GM Brake master cylinder removal tool. Often needed for installing hydroboost set-ups
$40.00 plus shipping
Borgeson Steel steering U-Joint 014349. 1" - 48 spline by 3/4"DD $75.72 at Summit.
Two Corbeau Forza seats. One in good shape, the other has a cover with a worn side. Both need a seat bottom cushion, which were lost in a fire. Not sure shipping costs would be reasonable.
$200 for the pair.
Aluminum Small block Chevy water pump - not sure how I ended up with it, thought all I had were big block water pumps. Looks to have some silver paint on it.
$30 plus shipping
Old 02-25-2014, 08:23 AM
1nastyZ06 1nastyZ06 is offline
Will the dash insert fit for 69 Camaro dash replacement?
Old 02-25-2014, 10:13 AM
Devil Dog's Avatar
Devil Dog Devil Dog is offline
Default Water Pump
PM Sent.
Semper Fi
Old 02-25-2014, 04:42 PM
31069ss's Avatar
31069ss 31069ss is offline
Who makes the dashes and what car/ year were they for ?
Old 02-25-2014, 05:36 PM
70Nova's Avatar
1NastyZ06 - I'm not sure that it will or will not fit. I've not had a Camaro dash to check against.
31069ss - I was going to use this on the 70 Nova by using the plastic Nova dash insert and cutting out the instruments but it didn't really fit well. They were made by my son.
Old 02-26-2014, 05:38 AM
patobusta patobusta is offline
Would your son make some dash inserts for a second gen?
I will be first on line!
Old 02-26-2014, 07:08 PM
31069ss's Avatar
So that dash will drop In a 69 nova suby no problems ?
Old 02-26-2014, 07:26 PM
70Nova's Avatar
I don't think I can make that happen.
No, it didn't really fit well in a Nova dash.
Old 03-01-2014, 11:16 PM
TwoTiredTires TwoTiredTires is offline
PM Sent
"The Race Is long...But In The End It's Only With Yourself"
Old 03-02-2014, 10:01 AM
31069ss's Avatar
Thanks for the info . That's a good looking dash too bad it doesn't fit
