Old 02-28-2014, 08:06 AM
Deserve's Avatar
Deserve Deserve is offline
Default Exhaust that fits with Ridetech Stage 2?
Doing my research it looks like a number of people simply stop the exhaust just short of the rear axle so it doesn't get in the way. Some people run it under the axle. I guess my question is that if I go with a Magnaflow x pipe type system, can I make it work with my new Ridetech suspension in one of these ways. Is there a better way?
Old 02-28-2014, 06:42 PM
70 tt rustang's Avatar
70 tt rustang 70 tt rustang is offline
Dump them out the side in front of the rear tires
Old 03-01-2014, 02:18 PM
bret's Avatar
bret bret is offline
Supporting Vendor
Tailpipes (which I recommend) will be a custom fitment. We typically run them under the axle. While that may sound a little "hillbilly" the reality is that the axle sits so far up in the car that you still have to turn the pipe up out of the muffler to get under the axle. We do it like that on velocity and the 48 Hour Camaro...works and looks good.
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 03-01-2014, 06:05 PM
Bad94 Bad94 is offline
I have the RideTech 4 link, on my nova. and I did 3" up and over the axle and around the tank.
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 03-01-2014, 07:01 PM
bret's Avatar
Supporting Vendor
There you go!
Bret Voelkel
President
RideTech
Old 03-03-2014, 05:23 PM
Vince@Meanstreets's Avatar
beautiful job!!
I see a 90,straight,180, 45, straight, 45, 45
Is that a 180 or a 90 into a 45?
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 03-03-2014, 07:52 PM
beautiful job!!
The complete system started with U bends, and then cut the angle/degree we need.
Old 03-04-2014, 07:12 AM
Deserve's Avatar
Wow! I really like that set up. Thanks for the input all. I went with Stainless Works. It looks like I'll be able to run it up and through in a very similiar fashion and I like the tone. It will be here in 3 1/2 weeks. I'll let everyone know how it turns out. So far the Ridetech install is going pretty smooth. It's in and just needs to be aligned and driven for a bit to make sure there isn't any fender rub. Hopefully, it'll get done this weekend minus the new exhaust.
BTW Ridetech customer service is awesome. I had a duplicate part and they sent a replacement over night.
Old 03-04-2014, 07:32 AM
130fe 130fe is offline
Post
I used the kit that Stainless Works used to sell, was called "Prodigy Pipes" or something like that. I heard they will only sell it if you buy their exhaust set up.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
