Old 03-03-2014, 12:50 PM
Default How much oil in LS7 with ats/petersen tank?
How is correct oil level checked when using ats/petersen sump wich has no dipstick? And is there any tricks how to first start and prime brand new crate ls7?
63 Z06
Old 03-03-2014, 01:49 PM
71RS/SS396's Avatar
How big is the tank? I would start out with whatever the manufacturer states the tank size is ( 2.5 gallon...etc). I would pull the spark plugs and fuel pump fuse and roll it on the starter until I saw pressure on the gauge, then reinstall the plugs and fuse. The proper level needs to be checked with the engine running, the oil level should be up to the screen in the tank.
Old 03-03-2014, 04:42 PM
Flash68's Avatar
Flash68 Flash68 is offline
There is no perfect oil line per se such as with a dipstick, but generally your fill amount is going be between 1/2 full and 2/3 full in a tank like this.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 03-03-2014, 06:08 PM
Ron in SoCal's Avatar
Here's how we did the first start up - fill the tank 1/2 way. Prime as Tim suggested above. After running for a few a few minutes, turn the motor off and fill to about 2/3rds, and not above the internal baffle.
Ron in SoCal
69 Camaro in progress
Old 03-04-2014, 05:52 AM
Thanks guys,
Owners manual for z06 vettes tell at oil should be check 5 minutes after warm engine has been shout down. I believe same goes with petersen sump.
63 Z06
Old 03-08-2014, 02:31 PM
gnx7's Avatar
gnx7 gnx7 is offline
Between 1/2 and 2/3 full measured in the tank while running and warmed up. If its too full... it'll puke out the breather (mine resides outside the car or it'll stink it up like crazy inside). Peterson 3 gallon tank with heater and same brand breather. My differential also goes to this breather in my RX-7.
Mine fully dry takes about 14 quarts. Between oil changes it is 10. The rest sits in the -16AN lines running from the pan to the oil tank (behind passenger seat), Setrab oil cooler up front.
