Old 03-07-2014, 02:10 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Default Trunk whetherstripping question
Hi
I noticed whenever I wash my car that water accumulates in the trunk channel where wetherstripping is placed. As a result of that Evertime I have to remove the wetherstripping, dry the channel area, then place the wetherstripping back again.
So is this the normal practice when washing the car or there is something not right that needs to be addressed?
Will appreciate your input guys and advise
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 03-07-2014, 06:54 AM
dhutton dhutton is offline
I think it is supposed to be glued in. The adhesive will seal out the water. At least that is what I do.
Don
Old 03-07-2014, 07:04 AM
Vince@Meanstreets's Avatar
Yep, use the appropriate rubber strip glue. Also make sure your seal gap is located near the trunk latch.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 03-07-2014, 07:28 AM
ProPont ProPont is offline
3m black weatherstrip adhesive glue is what I prefer. Apply the glue to the weatherstripping not to the channel. Also do it in sections and once applied to the weatherstripping push it in place and carefully lift it up and down. This allows air to get between it and set up faster.
Old 03-07-2014, 07:39 AM
72Z/28's Avatar
Thanks guys, I do have the 3M wetherstripping adhesive but was not sure where I should apply it. Is it applied on the outer edge of the wetherstripping or the inner edge facing the trunk?
72 Camaro RS:SOLD
68 Camaro:
Old 03-07-2014, 07:46 AM
I usually apply it to the bottom surface, if not. Inner surface facing trunk
Old 03-07-2014, 12:52 PM
72Z/28's Avatar
Thanks scott,will do that
72 Camaro RS:SOLD
68 Camaro:
Old 03-07-2014, 07:53 PM
glassman's Avatar
glassman glassman is offline
Apply it to both surfaces, lightly. Much like contact adhesive. We used to call this Gorilla Snot...(was an auto glass guy for 15 years)
Mike
Old 03-07-2014, 11:33 PM
72Z/28's Avatar
You are right applying it to both inner and outer edges woulb better. The main concen is water runs through the channel so applying on the outer surface will prevent water ingress into the channel
72 Camaro RS:SOLD
68 Camaro:
