Closed Thread
Old 03-07-2014, 04:40 PM
HotRodV6's Avatar
HotRodV6 HotRodV6 is offline
Default 93 M29 T56---freshly rebuilt by Texas Drivetrain Performance
Item Location (City/State): Austin Tx.
Price:3000 shipped
Description:
I have a 93 M29 Close Ratio T56, it has the same gear ratios as the 2001-2004 ZO6 corvettes. It has been freshly rebuilt to stage 2 specs by Texas Drivetrain Performance in Ft. Worth. It has the bell housing, clutch fork and pivot, & the slave cylinder spacer. I also have a lightly used B&M Ripper shifter with a B&M Hammer T-Handle, a new bronze shifter bushing, and a new stock replacement clutch kit that goes with the trans, and a stock replacement flywheel.
This trans does not have the skip shift solenoid, it was removed from a 93 trans am and was stuck in third gear when i bought it, i thought it was a busted shift fork, but it turned out that one of the synchronizer keys came loose on third gear causing it to be locked in gear. everything else in the trans was very clean, only some slight wear on the main shaft, which TDP welded up the shaft and machined it back down so that the gear/bearing has an actual press fit rather than the factory slip fit.
SOLD SOLD SOLD SOLD
Mike
1992 GMC Sonoma GT #492
58K original miles.
1993 S10 RCSB
LT1/T56 Project
For Sale
1993 S10 RCSB
4.3/Auto
Engine Rebuild in progress
2006 Hyundai Tiburon GT
2.7 V6/5 speed
Daily Driver
Old 03-07-2014, 05:55 PM
wayward wayward is offline
I highly recommend TSP work - great quality
Old 03-11-2014, 04:26 PM
HotRodV6's Avatar
bump ttt
Mike
58K original miles.
1993 S10 RCSB
LT1/T56 Project
For Sale
1993 S10 RCSB
4.3/Auto
2.7 V6/5 speed
Daily Driver
Old 03-12-2014, 07:52 PM
HotRodV6's Avatar
bump ttt
2700 shipped
Mike
58K original miles.
1993 S10 RCSB
LT1/T56 Project
For Sale
1993 S10 RCSB
4.3/Auto
2.7 V6/5 speed
Daily Driver
Old 03-17-2014, 05:16 PM
HotRodV6's Avatar
Bump ttt
I now have a stock replacement flywheel and the slave cylinder spacer that will go with the trans, and also wanted to add that the clutch will come with ARP pressure plate bolts.
Mike
58K original miles.
1993 S10 RCSB
LT1/T56 Project
For Sale
1993 S10 RCSB
4.3/Auto
2.7 V6/5 speed
Daily Driver
Old 04-26-2014, 09:01 PM
HotRodV6's Avatar
SOLD, Please Delete.
Mike
58K original miles.
1993 S10 RCSB
LT1/T56 Project
For Sale
1993 S10 RCSB
4.3/Auto
2.7 V6/5 speed
Daily Driver
Closed Thread
