Old 03-10-2014, 03:43 PM
ADiCarlo ADiCarlo is offline
Default Positioning Wheels For Measuring Axle Size
Does anyone know how much room you should have between the inner barrel and the wheel tub when determining axle size on a 68 Camaro.
I have a Quadralink and i'm trying to determine where to position the wheels in relation to the tub to get the final numbers. This should also account for any motion of the suspension so it doesn't rub.
I'm trying to get the wheel as close as possible to the tub because i'm going to increase the outer lip size as far as I can (wheel is a 10 shooting for a 12 or 12.5 if I stretch the fender)
Old 03-12-2014, 03:19 AM
no go nova's Avatar
no go nova no go nova is offline
I also need to know this. I think you need 1/2" min. on both sides to account for side shift/ tilt movement.
Old 03-19-2014, 03:18 PM
Called DSE and they said 1 inch from wheel to tub.
