Old 03-11-2014, 05:18 PM
jeremy30thz's Avatar
jeremy30thz jeremy30thz is offline
Default Stainless Works 3" exhaust system for LS, small or big block 67-69 Camaro CA67693S
Item Location (City/State): Greenwood SC
Price: $700 plus shipping
Description: Stainless Works 3" exhaust system for 67-69 Camaro
Item # CA67693S
1 of the mufflers got damaged in shipping see pics!!
Comes with a 3 bolt flange that bolts directly to Stainless Works headers to give you a true full 3" system.
This system can be used with LS engines as well as small and big block engines
1967-69 CAMARO CNC mandrel bent huge 3" diameter 304 stainless. Designed to fit aftermarket headers with 3" 3 bolt flanges. Some cutting and welding is required for installation. No crossover with dual 304 stainless turbo mufflers. Exits behind rear tire between quarter panel and leaf spring. Hot rod system for 67-69 small block or big block Camaro. Also works with LS engines
