Old 03-13-2014, 07:17 PM
fillpot fillpot is offline
Default American Auto Wiring and LS swap
Guy's doing a rewire on my 69 Camaro with a ls2 swap and using the American auto wiring classic update kit and was just wondering about running the purple wire and some others to the starter on the directions, are ya'll doing this on LS swaps or is this just for older engines, guess it basically works the same huh? not a complete dumbass lol but was just wondering, btw super nice wiring kit. THANKS!
Old 03-13-2014, 08:12 PM
Che70velle's Avatar
Yes, I am on my Chevelle. What harness are you running for engine controls?
Thanks Dad!!
Old 03-13-2014, 08:13 PM
Z06vette's Avatar
Z06vette Z06vette is offline
Default wiring
The purple is the nuetral safety. Unless you have one already, you need to run it. My engine harness is a modified 99-02 F body harness & it had the purple wire included in it. Not sure what engine harness you are running.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 03-13-2014, 09:05 PM
Thanks guy's it's the stock Ls2 harness that's been reworked by speartech, I've had the American auto wire kit for a while but just hadn't took the time to install it until for some crazy reason I fried a pcm the other day, the wiring harness that was in the car was garbage and had a bunch of lt1 wiring integrated into it (car came with a lt1), so I tried to take two 69 Camaro harnesses and make one, worked for a while but was always leary of it, thanks for the help sure Im going to have some other questions lol. THANKS!
Old 03-14-2014, 08:00 PM
What about the pink wire for the engine wiring on the American auto wire harness THANKS!
Old 03-14-2014, 09:17 PM
130fe 130fe is offline
Post
That pink wire is for the pcm ign.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 03-15-2014, 12:39 AM
Chris, thanks man just came back in from working on the car and I guess I'm loosing it because I don't even no where pink came from lol, Im still just rewiring the car it self not even wiring up the motor, any way got it going my, got your pm also I'll be in touch. THANKS!
Old 03-15-2014, 08:48 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Are you going to relocate the battery in the trunk with a remote starter solenoid?
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 03-15-2014, 01:23 PM
I am going to put it in the trunk but not sure about the starter solenoid yet. THANKS!
Old 03-15-2014, 01:51 PM
If you do it this way, would you wire the one in the trunk and then to the one on the motor?
Chris
1968 Camaro SS
LS3/T56
