Old 03-13-2014, 10:09 PM
1Bad68Cat 1Bad68Cat is offline
Default Centerlock Wheels
Hello All,
I am looking into getting new wheels for my 67 cougar. I plan to get centerlock type wheels strictly for the looks, but was wondering if there are any issues I should be concerned about (maintenance, stripped center spud?, etc) that maybe I should just stick to a traditional attachment. I am typically a function over form guy, but really like the look of the centerlocks. What are the PT faithful's opinions?
Robert
Old 03-14-2014, 09:18 AM
Forgeline Wheel Forgeline Wheel is offline
Originally Posted by 1Bad68Cat View Post
Hello All,
Robert
Hi Robert,
Thanks for considering Forgeline products!
Typically there are 2 legitimate tradeoffs that customers should consider with the centerlock conversions:
1. They add about 5 lbs of unsprung mass to each corner. Fortunately, this is mass concentrated at the hub in the very center of the wheel, so it is not as detrimental as would be 5 lbs at the outside of wheel. But it is an extra 5 lbs nevertheless.
2. There is extra specialized hardware involved with getting your wheels on and off. Specifically three things: the adapter for the Flush Loc center cap, the adapter for the center lock nut itself, and the big two foot long breaker bar that you need to generate enough torque to loosen (and tighten) the main center locking nut. Plus, if you happen to opt for the GT style nut (as opposed to the hex nut), then you have yet another adapter (to adapt the hex tool to the GT nut). So potentially four extra pieces of hardware, in the case of the GT nut. And you pretty much need to take these tools with you wherever you go, because without them, you can't remove your wheels, in the event of a flat tire or some other problem.
And of course, it is fairly important to keep the center lock nuts greased. The aluminum nut and metal adapter are similar enough materials, and the 300 lb-ft of torque is great enough, that there is a chance for galling. And if galling occurs, then it makes it really hard to get the nut back off.
Mark Schetter
Forgeline Motorsports, LLC
Dayton, Ohio
1-800-886-0093 x12
[email protected]
www.forgeline.com
Subscribe to our monthly newsletter here!
Last edited by Forgeline Wheel; 03-14-2014 at 11:46 AM. Reason: 300 lb-ft, not 400 lb-ft...
Old 03-14-2014, 09:34 AM
Originally Posted by Forgeline Wheel View Post
Hi Robert,
And of course, it is fairly important to keep the center lock nuts greased. The aluminum nut and metal adapter are similar enough materials, and the 400 lb-ft of torque is great enough, that there is a chance for galling. And if galling occurs, then it makes it really hard to get the nut back off.
Thanks Mark for replying. I sent you a PM.
Robert
