Old 04-02-2014, 02:06 PM
68LS1's Avatar
68LS1 68LS1 is offline
Question What Crossmember 2nd Gen DSE frame & T56?
As per title I'm looking for a crossmember for my 1970 Camaro, to suit T56 Magnum install in DSE subframe
What have others used?
thanks
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
Old 04-03-2014, 07:17 PM
68LS1's Avatar
Now advised by DSE that they use same hydro formed rails for both 1st Gen & 2nd Gen subframes, so crossmember bolts in in 1st Gen stock position, not stock 2nd Gen position.
This means I am looking to use a 1st Gen crossmember? Concern is that there may be some fouling on floor?
So has anyone installed a T56 in a 2nd Gen DSE subframe? What crossmember worked for you?
Roger
Old 04-04-2014, 07:26 AM
toddoky toddoky is offline
I think your best bet would be the ATS T56 1st-gen crossmember since I believe it does not extend up into the floor pockets that are present on a 1st-gen. The last question to answer is whether the DSE 1st and 2nd-gen engine mounts have the same amount of set-back, because that will affect the installed fore/aft position of the transmission isolator relative to the crossmember attachment holes in your subframe. Your best bet for fitment validation would be to measure the offset distance from the rear attachment hole in your subframe to the mounting holes in your transmission isolator and call Speedtech Performance (the new owner of the ATS crossmember designs) and ask them if their 1st-gen crossmember can be adjusted to accommodate that amount of set-back.
Old 04-04-2014, 03:22 PM
68LS1's Avatar
Yeah was hoping Jay or Blake may have seen this and responded.
I do have the ATS crossmember (1st design) in the 68 so I have a reference to look at, measure when the time comes.
Roger
Old 12-14-2014, 12:15 PM
Bump for any updates
