Old 04-03-2014, 10:17 AM
Twinstang's Avatar
Twinstang Twinstang is offline
Default 69 camaro mini tubs with 345/30/19 tire
Just wondering using stock frame rails obviosly notched and plated on a 69 camaro running a 12".5 wide rim with a 345/30/19 tire can it be done with DSE. tubs or do I need to modify the outer wheelhouse also ?
Also has anybody used the chrisalston chassis works mini tubs they look to be similar to the DSE Mini tubs and what's your experience with them if you have used them.
Thanks,John
Old 04-03-2014, 01:57 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Check out the Speedtech red camaro, I believe it's got 345/30/19s
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 04-03-2014, 02:05 PM
Here is mine with DSE minitubs and notched frame. We did cut the fender lip but it's not a factor with a 345 and the right offset.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 04-03-2014, 04:03 PM
Twinstang's Avatar
Thanks guys that's what I needed to know.
Nice car do you have more pics of it.
Old 04-03-2014, 07:56 PM
Thanks!
I have a build thread on here but just picking up steam again. That was a test fit if the wheel/tire I plan to run. Not my wheels sadly.
Check my thread out though. More photos there!
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 04-03-2014, 11:59 PM
efs69's Avatar
efs69 efs69 is offline
I used the Alston mini tub kit on my 69. I chose them because the kit came with the close out panels that saved on fab time. Other than the shape being slightly different they are the same and use the same process to install as the DSE.
Old 04-04-2014, 08:02 AM
Twinstang's Avatar
Thanks I think I might try using them
