Old 04-05-2014, 08:25 PM
walken100 walken100 is offline
Default Rear Sway Bar Attachment
Ok, hopefully a simple question. I've had to re-layout my torque arm to allow for wider tires and some adjustability. Part of the work is adding a new sway bar. Turns out that a real clean place to mount the arms is near the end of the lower control arm. I know I've seen this done before and just wanted to see if there are any issues that I should be aware of especially from anyone that has done this. I am aware that this affects the actual resistance calculation through the range of travel but it seems like it should be inconsequential.
I've attached a picture of approximately where I would add the mount to the control arm.
Input is appreciated.
Bart
Old 04-05-2014, 10:47 PM
Vince@Meanstreets's Avatar
that should be fine but it puts a lot of force in that weld and single fastener....can you create a bracket to weld to the link bracket itself? or axle tube?
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 04-06-2014, 02:17 PM
Yup....
Its just so clean on the control arm. However adding metal to the control arm bracket taint hard.
Thanks.
